Genius tires?
Got to check these out this weekend. As said above they are airplane casing they are 22 ply sidewall and have a load rating of 32,000 lbs each. :o :****: HAHAHA They had 150 lbs of air pressure in them to seat the beads and started letting air out slowly to see how low they could get them. Lowest I heard and able to drive was like 50 lbs. Some very good looking tires just think they will have to change the casing.
did you happen to get any prices?
Cole said:
"There on airplane casings way to heavy and there 22 ply. if u put them on beadlocks the bolts would have to 2.5 long and that's too much ....the 43" are $650 plus freight." From Scott GoforthHe is looking into have some put on super Swamper casings.
:dunno:
Maybe it's just me but every time I watch the back flip videos that guy in tha army greenish shirt sure can fawkin run!! And stop! Hahaha.
Back on subject i would imagine these tires would be some hill killin bastards. Like said above, my first reaction was "fourwheeler tire"
They took out Brandon's output shaft pretty quick at the SRRS race. Left black marks all across the dirt ledge and no cleats came off
Genius Tires is on to something, they just need a little tweaking, these things are straight up dig tires, they hook extremely well, cant wait to get these on some double beadlocks where I can run lower pressure, gonna play with things on rocks to see what happens
Brandon posted they listed the 43 at just over 98lbs. That is hard to believe with them being 22 ply sidewalls and the bead is probably double think to. Just like the 53in military tires. They are also 22 ply tires
By the looks of the backflip, they hook hard and he must have had them filled with helium....or it could just be that Ford motor :eek: :woot: booyang
