good luck on ____ at harbor freight...
Re: Re: good luck on ____ at harbor freight...
grcthird said:
I got a set of the wheel jack dollies and have used them alot lately. Makes moving a dead car around in a shop much easier than just normally pushing one. They would be good for wrecked cars with messed up struts at a body shop.
Which ones? I've been needing some
I've had good luck on returns...........they are pretty good at taking back their POS tools.......
ranger11 said:
Ive owned both. No complaints. I sold the 12 ton to get the 20 so I could buy the swag press brake.
RebelRider said:
I have the 12. It works ok, but it's a bit sloppy. When putting pressure on something, it tends to push the jack to the side and try to spit out the thing your pressing. I'm sure a little fabricating would fix it.
JohnG said:
I have the 20 ton grey model. Nice unit. Added the air over hydraulic unit from them. Also have the SWAG finger brake in it.
Sent using left thumb.
Thanks guys .. bought one yesterday and put it together last night .. pressed in a set of balljoint nicely.. I think it'll work good for my use.
Sent from my SAMSUNG-SM-G890A using Tapatalk
Bumping this thread, cause lack of monies.
This guys lingo is better than the tools
https://m.youtube.com/watch?v=3ZfYF9aIO7U
I have a few things.
Latest being a compressor pump. I had one of the biggest home depot compressors for over 10 years. The compressor finely throw a bearing. So after looking around at all the options I got one from Harbor Freight. The only problem I have had was hooking it up. Getting the air lines hook up was a royal pain in the ass. But that's what all the reviews said. It was been running for about 6 months now in my garage / shop.
https://www.harborfreight.com/145-psi-5-hp-twin-cylinder-air-compressor-pump-67698.html
I also picked up one of these about 2 month ago. So far it has not given me any problem.
https://www.harborfreight.com/10-amp-deep-cut-variable-speed-band-saw-kit-63444.html
I love it so far. Already have worn out a blade. I have 2 band saws, chop saw and a plasma cutter in the garage / shop. And I tend to grab this first.
I also picked up a porta power about 2 years ago. Needed to bend / straighten an frame rail on a jeep. It has work flawless. Just had to add hydraulic fluid to it before I used it the first time. No big deal.
I chose the10 ton over the 4 ton. I didn't want to be where 4 ton wasn't enough and then have to go out and get the 10 ton.
https://www.harborfreight.com/10-ton-super-heavy-duty-portable-hydraulic-equipment-kit-62114.html
Buddy has two of the generators, seems to be build well and they are supper quite
Sent from my SM-G935V using Tapatalk
Eddyj said:
I can't even tell you how many times I've busted my ass in that little chair. I tack welded the wheels on.
I tack welded them on too but it broke again and I said F'it and tossed it.
Sorry if I missed it, but any reviews on their Predator inverter generators?
I've had the 3500 one for about 4 months and have been really impressed. It may **** the bed on the next outing but so far so good.
It has most of the features of the Honda and is just as quiet.
Electric start with built in battery, low oil shutoff, digital readout, economy mode, parallel compatible, etc.
I wish it had was a fuel gauge but at 1/3 the price of a Honda EU3000, I'll get by without one.
I gave just a tad under $700 out the door with coupon.
Only negatives for me are the small wheels aren't worth a **** for anything but hard surfaces and I had to buy an adapter to make my 4 prong generator cord work with it. (110volt output only instead of 110/220 on my old loud generator)
I picked one up for the new years sale and so far is has been awesome! very quiet and seems to be efficient My cousin has been running one for his camper at the hunting camp all winter without any troubles. It sits right outside the camper and runs all night.
https://m.harborfreight.com/390-Lumen-Magnetic-Slim-Bar-Folding-LED-Worklight-63958.html
This is a bad little dude I caught it on sale for 20 bucks
