buster_X2
Member
how does everyone recomend making half doors for a 84-88 toyota, with the regular doors?
Do mean how to mark and cut them ? or what type of design ??
any reason for keeping the top of the window frame?
I did my doors on my old yota and cut the window frames off but on the next set of doors I will leave the window frame it gives it a more finshed look, Also if you are not running a cage it will make the cab stronger It may sound silly but it does.
As for the indent for the handles if you leave part of them you can just cut a small piece of sheet metal to cover the indent and weld it or you could put a few relief cuts and use a hammer and dolly to shape it how you want.
i'm having trouble actually making welds work on sheetmetal. to avoid burning through it all, do you turn the wire speed up and the volts down? i can weld thick stuff fine, just not skilled enough for the fragile paper thin stuff. what can i say, i'm a newb
To be honest thats what seperates those who/cannot weld. Its tricky and not easy to master---practice :awesomework:
