half doors
Why do you hate welding on sheetmetal? A weld is a weld, I don't hate welding sheetmetal any more than welding 3/8" plate.
what would be, if any... the right welding machine for the average sheet metal welder?
:corn:
Lil 110 machine...
Do auto body shops / certified welders / etc, have some secretive oath they take and swear by death never to reveal?
:D I think practice & lot's of patience helps... but not much.
Big part---heat and wire speed and then technique
There's no secret oath, you just have to be able to see when the melt down is coming, skip ahead a bit before it happens, and come back quick. Perfect fit is key. **** I'm a horrible teacher, don't listen to me.
you can pop it in, make a tack, stop for 5 sec, then a tack just ahead of the one you just made, making sure that they overlay fully. this is the noob way of doing it. If you are doing a ton of sheetmetal work i would set up a hardwire setup. with a small wire....
"Anyone can learn the weld in 10min. Mastering it takes a life time"
i have a lincoln 135... i used the flux core wire and the heat turned all the way down... wire speed on 2.5... it worked for me.... pics of my doors primered for paint
just my 2 cents
it sucks cause i like to weld thick ****. like 1/2 inch. thats what i use for all my suspension mounts on my truck. just because i can burn it with out punching through. all about penetration... thats funny, isn't that what life is about too? penetration...
