Help with rotors
you have to take off the brake caliper first:haha: :haha: :haha: Ok you got rust sticking them on get a Big hammer and hit BETWEEN the wheel stud and it will pop off.
MADDMUDDER said:
are you sure cuz i beat the hell out of them..but will try again:beer:
Some have a small retaner clip on the wheel studs if your do just take them off they are for asm. line so rotor wont fall off as it goes down the line We are talking about the rotors only. HIT IT.
You need to get a jack first, then put it on jack stands. Once you lift it up and you use the lug wrench to loosen the lug nuts remove the wheel...oh wait...did you finally get a jack:flipoff:
MADDMUDDER said:
no little clips yes it was on a stand and yes the claiper is off still wont come off
BIGGER HAMMER there is nothing else be rust holding them on. If they are stuck that bad be ready to buy new rotors so know from the back side with the calipers off beat the living :poo:out of it on the out side corner they will come off.:corn:
PLEASE tell me it's not a 2wd? They have a cap in the center with a nut that keeps them on. (I couldn't believe they came in 2wd till I saw one)
