redneckengineered
Trailer Park Panty Dropper
KyTrash said:I think that you can get 4.88 gear for HP-70?
Nope, that's a Super 60 gearset. 5.13 is the only available ratio for a HP70. Trust me.
Why? Totally different animal than a 14BFF. They have 33-spline C-clipped axle shafts if I remember correctly. Not to say that it can't be changed, but D60 is 35 spline stock at the carrier. Seems like a step backwards from even a D60 ???irondalefj80 said:has anyone ever throught about using a semi-floating 14 bolt for the center section?
jordan7118 said:Front 60s - as far as I know - were all 35-spline at the diff, which is what we'd be comparing if you swapped to a 14BFF or 14BSF chunk for steering.
Dually is actually the housing you want if you want true beef. They have thicker tubes, thicker diff housing around the tubes (I believe...), and are the same backing plate to backing plate in width. The difference comes from the extended length spindles.
EDIT: I'm trying to find out about the dually differences and it being the desired axle for making steer...
irondalefj80 said:i've been thinking bout the hp60, but then i have to swap the entire drivetrain....
Bronco Buster said:Why would you have to swap the whole drivetrain? If you are going to build a custom axle anyway just put Chevy tubes on a ford housing. It will still be custom but with stock easier to get parts. Just because the HP60 is a driver drop doesn't mean you can't use the center section.
lay said:if you do build a custom front might as well go with a 14bolt cheaper to find than a hi 60 and gunna be the same amount of work! just my 2 cents but u better swap tcases if you drive hard and do build a tuff as fawk front cause the 300 aint going to hold.
irondalefj80 said:i dont play toooo hard... i'm stepping up from a K5 fullsize. i'm just trying to see what people recommend. i have a 44 chromo right now, and i was gonna build a new front axle while i can still wheel, and when i get it done, swap it in. what do you recommend? the 14bolt?
I have a buddy who has access I may just go steering 14.TBItoy said:downside to a HP60 (ford 60) is that everyone I know that has/had one broke at least one knuckle, and most broke knuckles and Cs... The Ford outers are thin... you can beef them up and gusset them though.
You mentioned a 14 bolt with rock outers. This can be done relatively low dollar if you run stock shafts or the Ouverso In stock 16 spline chromos. Helps if you have a lathe or access to a lathe.
TBItoy said:You mentioned a 14 bolt with rock outers. This can be done relatively low dollar if you run stock shafts or the Ouverson stock 16 spline chromos. Helps if you have a lathe or access to a lathe.
