Holley Terminator EFI (Ford small block efi options)
Re: Holley Terminator EFI
Put a cut down mustang harness and a A9L computer in it the mustang wiring and computer is already set up for 351 firing order hence 302 HO that's what I have and will not have anything else fires and idles all day long don't run hot and breaks the **** out of every rock shaft I've had in it :****:
Re: Re: Re: Holley Terminator EFI
I thought about it, but I'd have to source all that, plus get tuning software/hardware, etc.
What's your reasoning behing the computer controlling the spark? Seems like that would just be something else that could mess up.Are you thinkink it would be easier to dial everything in ?
Funny as this sounds (especially to old school guys), I'm a lot more comfortable/familiar with tuning something that you can simply punch numbers into a computer and let it take care of the timing curve... Rather than using vacuum, weights, and springs to control it like on a self contained HEI.
And it will save money on having to buy new ignition parts.
You can get a painless street rod wireing harness from summit that comes with all the sensors and I'd plug and play if you don't want to it down a mustang harness and it's a lot cheaper or you can get in touch with me and I'll try and help you as much as I can
One thing I definitely want to do is go to a standard carburetor style intake manifold, the factory 5.8 truck intake is huge and stupid, and all the "Ford efi style" intakes are huge and expensive.
What kind of throttle body/tps sensor would you use with the carb intake and Mustang efi stuff?
I'm not sure that it'd be cheaper by the time I sourced new injectors, fuel rails, throttle body, etc
