Eddyj
Eddyj said:Sent from my iPhone using Tapatalk
Eddyj said:![]()
I didn't want to turn this into an ls vs sbc thread but I 100% agree with you. Me and pete deck were talking about this last night. I don't know if it's rpm of torque ranges or what but a small block just feels like it's doing much more work than an ls. And for just pure toughness you can't beat the small block.onetoncrawler said:I have had Lane dyno a couple of buggies for me. one with an LS and one with a built SBC. the loss was substantial on both
here is some info for reference. I know that redneckengineering had a good thread similar to this a while back with a lot of good numbers... the dyno would hurt a lot of peoples feelings with their 6.0 with a texas speed cam
- The SBC was dynoed at the engine builder at over 500 HP at the crank (with a carb)
o ATK Engines Chevy 383
o Splayed 6 bolt mains
o 11.5/1 compression
o Brodix ported heads
o Roller cam/roller rocker combo
- same engine with Holley FI only put down 197 HP to the rear tires (TH400, Atlas, Gearworks 10" 5.43 and 42" treps) on 93 octane
so now my engine is being pulled to be built with a bigger cam and some more goodies because less than 200 hp at the wheels is just unacceptable! :****:
the LS that he done was mild
07 LQ4 6.0
Block Hugger Headers
LS2 intake, throttle body, MAF, and injectors
stock internals
running through a TH400, atlas, 14 bolt with 5.13's and 39" krawlers it made 230 HP at the wheels.
I can tell you that the SBC i have now seems a good bit stronger than the 6.0 that I had, but the dyno numbers show otherwise. Looking at what the 6.0 should have made at the crank VS what I know my SBC made at the crank the seat of the pants feel makes sense (SBC has 100 more HP)
So, I said all that to say this... you can't always judge an engine by the dyno numbers
EOR Racing Dyno Session
Defender Buggy Dyno tune
lowbudgetjunk said:iPhones are stupid. They steal 3hp just by owning one.
pholmann said:Chassis dyno I assume? What's the specs?
If it's from when trip had it done lane Culver did it but I don't know what size tires were on itDallasBlade said:I'm assuming this was a engine dyno? Paperwork was in a folder when i bought the jeep. It's just a 6.0, with a cam to my knowledge. I didn't know the loss of power through the drivetrain was that great, until I saw everyones number.
BUG-E J said:If it's from when trip had it done lane Culver did it but I don't know what size tires were on it
Elliott said:Lets see a full pic of these sheets, some look like the lines do not cross, if they do not cross at 5,250 then the sheets are bogus.
