How far can you push "street legal?" (Pics of you have them.)
All of these are street legal and are/were driven regularly on the street.
I've done the builders title in the past, and it is a complete pain in the ass. Lately I have been going the route of making the buggies look like a vehicle (jeep, toyota, etc) and then finding a rotted version of that vehicle to "donate" its VIN and title as the buggy is the end product of rebuilding that vehicle. You have the buggy inspected by law enforcement (to make sure it doesn't have any pre-existing VIN's) they sign off on the affidavit, and you go to the tag office where your newly "rebuilt" vehicle gets issued a new VIN hassle free with no inspection.
the samurai in my avatar i drove locally around town, the guy that had it before me before the front axle stretch and coil overs drove it all the time on the street with full hydro. i live in north gerogia.
That Scrambler is the bomb!!! Not sure how good it goes but it sure does look good!
Those were custom vehicle titles or old vehicle titles? (I assume the latter.)
How do they get insured? I've already discussed this with State Farm and they absolutely won't consider it.
The form you linked to on pirate is to get a title on the junk / scrap vehicle, correct? Once that is in hand you then register how?
gtmcgeejr said:
In Florida you can get a builders title. The vehicle must inspected by DHSMV (FHP) once you pass the inspection your good to go. The only requirements are your basic ones you've talked about. Lights, turn signals, windshield, wipers and head lights under 54". No fenders or mud flaps are required unless it came from the factory that way. There are sum bumper requirements but they depend on you vehicle weight. You can find the answers you need in FS 316. Good luck with your build.
Sent from my SM-N900V using Tapatalk
FS 316 does not mention anything about a builders title or custom title. I've now read most of the 300+ pages of 316 (yawn) and here are the parts that discuss vehicle requirements though ...
TITLE XXIII
MOTOR VEHICLES
CHAPTER 316
STATE UNIFORM TRAFFIC CONTROL
316.220?Headlamps on motor vehicles.—
(1)?Every motor vehicle shall be equipped with at least two headlamps with at least one on each side of the front of the motor vehicle, which headlamps shall comply with the requirements and limitations set forth in this chapter, and shall show a white light. An object, material, or covering that alters the headlamp's light color may not be placed, displayed, installed, affixed, or applied over a headlamp.
(2)?Every headlamp upon every motor vehicle shall be located at a height of not more than 54 inches nor less than 24 inches to be measured as set forth in s. 316.217.
(3)?A violation of this section is a noncriminal traffic infraction, punishable as a nonmoving violation as provided in chapter 318.
History.—s. 1, ch. 71-135; s. 172, ch. 99-248; s. 9, ch. 2000-313.
316.221?Taillamps.—
(1)?Every motor vehicle, trailer, semitrailer, and pole trailer, and any other vehicle which is being drawn at the end of a combination of vehicles, shall be equipped with at least two taillamps mounted on the rear, which, when lighted as required in s. 316.217, shall emit a red light plainly visible from a distance of 1,000 feet to the rear, except that passenger cars and pickup trucks manufactured or assembled prior to January 1, 1972, which were originally equipped with only one taillamp shall have at least one taillamp. On a combination of vehicles, only the taillamps on the rearmost vehicle need actually be seen from the distance specified. On vehicles equipped with more than one taillamp, the lamps shall be mounted on the same level and as widely spaced laterally as practicable. An object, material, or covering that alters the taillamp's visibility from 1,000 feet may not be placed, displayed, installed, affixed, or applied over a taillamp.
(2)?Either a taillamp or a separate lamp shall be so constructed and placed as to illuminate with a white light the rear registration plate and render it clearly legible from a distance of 50 feet to the rear. Any taillamp or taillamps, together with any separate lamp or lamps for illuminating the rear registration plate, shall be so wired as to be lighted whenever the headlamps or auxiliary driving lamps are lighted. Dump trucks and vehicles having dump bodies are exempt from the requirements of this subsection.
History.—s. 1, ch. 71-135; s. 1, ch. 79-97; s. 173, ch. 99-248; s. 10, ch. 2000-313; s. 17, ch. 2006-290.
316.222?Stop lamps and turn signals.—
(1)?Every motor vehicle, trailer, semitrailer, and pole trailer shall be equipped with two or more stop lamps meeting the requirements of s. 316.234(1). Motor vehicles, trailers, semitrailers and pole trailers manufactured or assembled prior to January 1, 1972, shall be equipped with at least one stop lamp. On a combination of vehicles, only the stop lamps on the rearmost vehicle need actually be seen from the distance specified in s. 316.234(1).
(2)?Every motor vehicle, trailer, semitrailer, and pole trailer shall be equipped with electric turn signal lamps meeting the requirements of s. 316.234(2).
(3)?Passenger cars and trucks less than 80 inches in width, manufactured or assembled prior to January 1, 1972, need not be equipped with electric turn signal lamps.
(4)?A violation of this section is a noncriminal traffic infraction, punishable as a nonmoving violation as provided in chapter 318.
History.—s. 1, ch. 71-135; s. 174, ch. 99-248.
316.2225?Additional equipment required on certain vehicles.—In addition to other equipment required in this chapter, the following vehicles shall be equipped as herein stated under the conditions stated in s. 316.217.
(1)?On every bus or truck, whatever its size, there shall be the following: On the rear, two reflectors, one at each side, and one stop light.
(2)?On every bus or truck 80 inches or more in overall width, in addition to the requirements in subsection (1):
(a)?On the front, two clearance lamps, one at each side.
(b)?On the rear, two clearance lamps, one at each side.
(c)?On each side, two side marker lamps, one at or near the front and one at or near the rear.
(d)?On each side, two reflectors, one at or near the front and one at or near the rear.
(3)?On every truck tractor:
(b)?On the rear, one stop light.
(4)?On every trailer or semitrailer having a gross weight in excess of 3,000 pounds:
(b)?On each side, two side marker lamps, one at or near the front and one at or near the rear.
(c)?On each side, two reflectors, one at or near the front and one at or near the rear.
(d)?On the rear, two clearance lamps, one at each side, also two reflectors, one at each side, and one stop light.
(5)?On every pole trailer in excess of 3,000 pounds gross weight:
(a)?On each side, one side marker lamp and one clearance lamp which may be in combination, to show to the front, side and rear.
(b)?On the rear of the pole trailer or load, two reflectors, one at each side.
(6)?On every trailer, semitrailer, and pole trailer weighing 3,000 pounds gross, or less: On the rear, two reflectors, one on each side. If any trailer or semitrailer is so loaded, or is of such dimensions as to obscure the stop light on the towing vehicle, then such vehicle shall also be equipped with one stop light.
(7)?On every slow-moving vehicle or equipment, animal-drawn vehicle, or other machinery designed for use and speeds less than 25 miles per hour, including all road construction and maintenance machinery except when engaged in actual construction or maintenance work either guarded by a flagger or a clearly visible warning sign, which normally travels or is normally used at a speed of less than 25 miles per hour and which is operated on a public highway:
(a)?A triangular slow-moving vehicle emblem SMV as described in, and displayed as provided in paragraph (b). The requirement of the emblem shall be in addition to any other equipment required by law. The emblem shall not be displayed on objects which are customarily stationary in use except while being transported on the roadway of any public highway of this state.
(b)?The Department of Highway Safety and Motor Vehicles shall adopt such rules and regulations as are required to carry out the purpose of this section. The requirements of such rules and regulations shall incorporate the current specifications for SMV emblems of the American Society of Agricultural Engineers.
(8)?A violation of this section is a noncriminal traffic infraction, punishable as a nonmoving violation as provided in chapter 318.
History.—s. 1, ch. 71-135; s. 1, ch. 76-31; s. 323, ch. 95-148; s. 175, ch. 99-248.
Note.—Former s. 316.276.
316.224?Color of clearance lamps, identification lamps, side marker lamps, backup lamps, reflectors, and deceleration lights.—
(1)?Front clearance lamps, identification lamps, and those marker lamps and reflectors mounted on the front or on the side near the front of a vehicle shall display or reflect an amber color.
(2)?Rear clearance lamps, identification lamps, and those marker lamps and reflectors mounted on the rear or on the sides near the rear of a vehicle shall display or reflect a red color.
(3)?All lighting devices and reflectors mounted on the rear of any vehicle shall display or reflect a red color, except the stop light or other signal device, which may be red, amber, or yellow, and except that the light illuminating the license plate shall be white and the light emitted by a backup lamp shall be white or amber. Deceleration lights as authorized by s. 316.235(5) shall display an amber color.
History.—s. 1, ch. 71-135; s. 2, ch. 86-23; s. 176, ch. 99-248.
316.225?Mounting of reflectors, clearance lamps and side marker lamps.—
(1)?Reflectors, when required by s. 316.2225, shall be mounted at a height not less than 24 inches and not more than 60 inches above the ground on which the vehicle stands, except that if the highest part of the permanent structure of the vehicle is less than 24 inches, the reflector at such point shall be mounted as high as that part of the permanent structure will permit.
(a)?The rear reflectors on a pole trailer may be mounted on each side of the bolster or load.
(b)?Any required red reflector on the rear of a vehicle may be incorporated with the taillamp, but such reflector shall meet all the other reflector requirements of this chapter.
(2)?Clearance lamps shall, so far as is practicable, be mounted on the permanent structure of the vehicle in such a manner as to indicate the extreme height and width of the vehicle. When rear identification lamps are required and are mounted as high as is practicable, rear clearance lamps may be mounted at optional height, and when the mounting of front clearance lamps results in such lamps failing to indicate the extreme width of the trailer, such lamps may be mounted at optional height but must indicate, as nearly as practicable, the extreme width of the trailer. Clearance lamps on truck tractors shall be located so as to indicate the extreme width of the truck tractor cab. Clearance lamps and side marker lamps may be mounted in combination provided illumination is given as required herein with reference to both.
History.—s. 1, ch. 71-135; s. 24, ch. 76-31; s. 177, ch. 99-248.
316.226?Visibility requirements for reflectors, clearance lamps, identification lamps and marker lamps.—
(1)?Every reflector upon any vehicle referred to in s. 316.2225 shall be of such size and characteristics and so maintained as to be readily visible at nighttime from all distances within 600 feet to 100 feet from the vehicle when directly in front of lawful lower beams of headlamps, except that the visibility for reflectors on vehicles manufactured or assembled prior to January 1, 1972, shall be measured in front of lawful upper beams of headlamps. Reflectors required to be mounted on the sides of the vehicle shall reflect the required color of light to the sides and those mounted on the rear shall reflect a red color to the rear.
(2)?Front and rear clearance lamps and identification lamps shall be capable of being seen and distinguished under normal atmospheric conditions at the times lights are required at all distances between 550 feet from the front and rear, respectively, of the vehicle.
(3)?Side marker lamps shall be capable of being seen and distinguished under normal atmospheric conditions at the times lights are required at all distances between 550 feet from the side of the vehicle on which mounted.
History.—s. 1, ch. 71-135; s. 25, ch. 76-31; s. 178, ch. 99-248.
316.251?Maximum bumper heights.—
(1)?Every motor vehicle of net shipping weight of not more than 5,000 pounds shall be equipped with a front and a rear bumper such that when measured from the ground to the bottom of the bumper the maximum height shall be as follows:
NET WEIGHT FRONT REAR
Automobiles for private use:
Net weight of less than 2,500 pounds 22? 22?
Net weight of 2,500 pounds or more, but less than 3,500 pounds 24? 26?
Net weight of 3,500 pounds or more 27? 29?
Trucks:
Net weight of less than 2,000 pounds 24? 26?
Net weight of 2,000 or more, but not more than 3,000 pounds 27? 29?
Net weight of 3,000 pounds, but not more than 5,000 pounds 28? 30?
(2)?"New motor vehicles" as defined in s. 319.001(9), "antique automobiles" as defined in s. 320.08, "horseless carriages" as defined in s. 320.086, and "street rods" as defined in s. 320.0863 shall be excluded from the requirements of this section.
(3)?A violation of this section shall be defined as a moving violation. A person charged with a violation of this section is subject to the penalty provided in s. 318.18.
History.—s. 1, ch. 85-158; s. 7, ch. 86-36; s. 23, ch. 91-221; s. 196, ch. 99-248; s. 18, ch. 2002-235; s. 7, ch. 2008-176.
316.252?Splash and spray suppressant devices.—
(1)?No person shall drive or operate, or cause to be driven or operated, any truck of gross vehicle weight of 26,000 pounds or more, any truck tractor, or any trailer or semitrailer the net weight of which is 2,000 pounds or more unless such vehicle is equipped with fenders, covers, or other splash and spray suppressant devices, such as substantial flexible flaps on the rearmost wheels of such vehicle or combination of vehicles, which will effectively prevent or minimize the splash or spray of water or mud and the throwing of other materials on the windshields of following vehicles. The provisions of this section shall not apply to vehicles used exclusively for the purpose of producing, processing, or transporting agricultural products, including horticultural products or forestry products.
(2)?The Department of Transportation shall adopt rules necessary for the implementation of this section.
History.—s. 1, ch. 87-165; s. 197, ch. 99-248.
316.261?Brake equipment required.—Every motor vehicle, trailer, semitrailer, and pole trailer, and any combination of such vehicles, operating upon a highway within this state shall be equipped with brakes in compliance with the requirements of this chapter.
(1)?SERVICE BRAKES; ADEQUACY.—Every such vehicle and combination of vehicles, except special mobile equipment not designed to carry persons, shall be equipped with service brakes adequate to control the movement of and to stop and hold such vehicle under all conditions of loading, and on any grade incident to its operation.
(2)?PARKING BRAKES; ADEQUACY.—Every such vehicle and combination of vehicles shall be equipped with parking brakes adequate to hold the vehicle on any grade on which it is operated, under all conditions of loading, on a surface free of loose material. The parking brakes shall be capable of being applied in conformance with the foregoing requirements by the driver's muscular effort or by spring action or by equivalent means. Their operation may be assisted by the service brakes or other source of power provided that failure of the service brake actuation system or other power assisting mechanism will not prevent the parking brakes from being applied in conformance with the foregoing requirements. The parking brakes shall be so designed that when once applied they shall remain applied with the required effectiveness despite exhaustion of any source of energy or leakage of any kind. The same brakedrums, brakeshoes and lining assemblies, brakeshoe anchors, and mechanical brakeshoe actuation mechanism normally associated with the wheel-brake assemblies may be used for both the service brakes and the parking brakes. If the means of applying the parking brakes and the service brakes are connected in any way, they shall be so constructed that failure of any one part shall not leave the vehicle without operative brakes.
(3)?BRAKES ON ALL WHEELS.—Every vehicle shall be equipped with brakes acting on all wheels except:
(a)?Trailers, semitrailers, or pole trailers of a gross weight not exceeding 3,000 pounds, provided that:
1.?The total weight on and including the wheels of the trailer or trailers shall not exceed 40 percent of the gross weight of the towing vehicle when connected to the trailer or trailers; and
2.?The combination of vehicles, consisting of the towing vehicle and its total towed load, is capable of complying with the performance requirements of s. 316.262.
(b)?Pole trailers with a gross weight in excess of 3,000 pounds manufactured prior to January 1, 1972, need not be equipped with brakes.
(c)?Any vehicle being towed in driveaway or towaway operations, provided the combination of vehicles is capable of complying with the performance requirements of s. 316.262.
(d)?Trucks and truck tractors having three or more axles need not have brakes on the front wheels, except that when such vehicles are equipped with at least two steerable axles, the wheels of one steerable axle need not have brakes. However, such trucks and truck tractors must be capable of complying with the performance requirements of s. 316.262.
(e)?Special mobile equipment not designed to carry persons.
(f)?"Antique cars" as defined in s. 320.08, and "horseless carriages" as defined in s. 320.086.
(g)?Four-wheeled motorized golf carts operated by municipal or county law enforcement officers on official business.
(4)?AUTOMATIC TRAILER BRAKE APPLICATION UPON BREAKAWAY.—Every trailer, semitrailer, and pole trailer with air or vacuum-actuated brakes, every trailer and semitrailer with a gross weight in excess of 3,000 pounds, and every pole trailer with a gross weight in excess of 3,000 pounds manufactured or assembled after January 1, 1972, shall be equipped with brakes acting on all wheels and of such character as to be applied automatically and promptly, and remain applied for at least 15 minutes, upon breakaway from the towing vehicle.
(5)?TRACTOR BRAKES PROTECTED.—Every motor vehicle manufactured or assembled after January 1, 1972, and used to tow a trailer, semitrailer, or pole trailer equipped with brakes, shall be equipped with means for providing that in case of breakaway of the towed vehicle, the towing vehicle will be capable of being stopped by the use of its service brakes.
(6)?TRAILER AIR RESERVOIRS SAFEGUARDED.—Air brake systems installed on trailers manufactured or assembled after January 1, 1972, shall be so designed that the supply reservoir used to provide air for the brakes shall be safeguarded against backflow of air from the reservoir through the supply line.
(7)?TWO MEANS OF EMERGENCY BRAKE OPERATION.—
(a)?Every towing vehicle, when used to tow another vehicle equipped with air-controlled brakes, in other than driveaway or towaway operations, shall be equipped with two means for emergency application of the trailer brakes. One of these means shall apply the brakes automatically in the event of a reduction of the towing vehicle air supply to a fixed pressure which shall not be lower than 20 pounds per square inch nor higher than 45 pounds per square inch. The other means shall be a manually controlled device for applying and releasing the brakes, readily operable by a person seated in the driving seat, and its emergency position or method of operation shall be clearly indicated. In no instance may the manual means be so arranged as to permit its use to prevent operation of the automatic means. The automatic and the manual means required by this section may be, but are not required to be, separate.
(b)?Every towing vehicle used to tow other vehicles equipped with vacuum brakes, in operations other than driveaway or towaway operations, shall have, in addition to the single-control device required by subsection (8), a second-control device which can be used to operate the brakes on towed vehicles in emergencies. The second control shall be independent of brake air, hydraulic, and other pressure, and independent of other controls, unless the braking system is so arranged that failure of the pressure upon which the second control depends will cause the towed vehicle brakes to be applied automatically. The second control is not required to provide modulated braking.
(8)?SINGLE CONTROL TO OPERATE ALL BRAKES.—Every motor vehicle, trailer, semitrailer and pole trailer, and every combination of such vehicles, equipped with brakes shall have the braking system so arranged that one control device can be used to operate all service brakes. This requirement does not prohibit vehicles from being equipped with an additional control device to be used to operate brakes on the towed vehicles. This regulation does not apply to driveaway or towaway operations unless the brakes on the individual vehicles are designed to be operated by a single control on the towing vehicle.
(9)?RESERVOIR CAPACITY AND CHECK VALVE.—
(a)?Air brakes.—Every bus, truck or truck tractor with air-operated brakes shall be equipped with at least one reservoir sufficient to ensure that, when fully charged to the maximum pressure as regulated by the air compressor governor cutout setting, a full service-brake application may be made without lowering such reservoir pressure by more than 20 percent. Each reservoir shall be provided with means for readily draining accumulated oil or water.
(b)?Vacuum brakes.—Every truck with three or more axles equipped with vacuum assistor-type brakes and every truck tractor and truck used for towing a vehicle equipped with vacuum brakes shall be equipped with a reserve capacity or a vacuum reservoir sufficient to ensure that, with the reserve capacity or reservoir fully charged and with the engine stopped, a full service-brake application may be made without depleting the vacuum supply by more than 40 percent.
(c)?Reservoir safeguarded.—All motor vehicles, trailers, semitrailers, and pole trailers, when equipped with air or vacuum reservoirs or reserve capacity as required by this section, shall have such reservoirs or reserve capacity so safeguarded by a check valve or equivalent device that in the event of failure or leakage in its connection to the source of compressed air or vacuum, the stored air or vacuum shall not be depleted by the leak or failure.
(10)?WARNING DEVICES.—
(a)?Air brakes.—Every bus, truck or truck tractor using compressed air for the operation of its own brakes or the brakes on any towed vehicle shall be provided with a warning signal, other than a pressure gauge, readily audible or visible to the driver, which will operate at any time the air reservoir pressure of the vehicle is below 50 percent of the air compressor governor cutout pressure. In addition, each such vehicle shall be equipped with a pressure gauge visible to the driver, which indicates in pounds per square inch the pressure available for braking.
(b)?Vacuum brakes.—Every truck tractor and truck used for towing a vehicle equipped with vacuum operated brakes and every truck with three or more axles using vacuum in the operation of its brakes, except those in driveaway or towaway operations, shall be equipped with a warning signal, other than a gauge indicating vacuum, readily audible or visible to the driver, which will operate at any time the vacuum in the vehicle's supply reservoir or reserve capacity is less than 8 inches of mercury.
(c)?Combination of warning devices.—When a vehicle required to be equipped with a warning device is equipped with both air and vacuum power for the operation of its own brakes or the brakes on a towed vehicle, the warning devices may be, but are not required to be, combined into a single device which will serve both purposes. A gauge or gauges indicating pressure or vacuum shall not be deemed to be an adequate means of satisfying this requirement.
(11)?VIOLATIONS.—A violation of this section is a noncriminal traffic infraction, punishable as a nonmoving violation as provided in chapter 318.
History.—s. 1, ch. 71-135; s. 3, ch. 92-296; s. 199, ch. 99-248.
316.271?Horns and warning devices.—
(1)?Every motor vehicle when operated upon a highway shall be equipped with a horn in good working order and capable of emitting sound audible under normal conditions from a distance of not less than 200 feet.
(2)?No horn or other warning device shall emit an unreasonably loud or harsh sound or a whistle.
(3)?The driver of a motor vehicle shall, when reasonably necessary to ensure safe operation, give audible warning with his or her horn, but shall not otherwise use such horn when upon a highway.
(4)?No vehicle shall be equipped with, nor shall any person use upon a vehicle, any siren, whistle, or bell, except as otherwise permitted in this section.
(5)?It is permissible but not required that any vehicle be equipped with a theft alarm signal device which is so arranged that it cannot be used by the driver as an ordinary warning signal.
(6)?Every authorized emergency vehicle shall be equipped with a siren, whistle, or bell capable of emitting sound audible under normal conditions from a distance of not less than 500 feet and of a type approved by the department, but such siren, whistle, or bell shall not be used except when the vehicle is operated in response to an emergency call or in the immediate pursuit of an actual or suspected violator of the law, in which event the driver of the vehicle shall sound the siren, whistle, or bell when reasonably necessary to warn pedestrians and other drivers of the approach thereof.
(7)?Notwithstanding the other provisions of this section, a trolley may be equipped with a bell, and the bell is not required to be used only as a warning device. As used in this subsection, the term "trolley" includes any bus which resembles a streetcar, which is powered by overhead electric wires or is self-propelled, and which is used primarily as a public conveyance.
History.—s. 1, ch. 71-135; s. 4, ch. 86-36; s. 1, ch. 88-91; s. 325, ch. 95-148; s. 203, ch. 99-248.
316.2935?Air pollution control equipment; tampering prohibited; penalty.—
(1)(a)?It is unlawful for any person or motor vehicle dealer as defined in s. 320.27 to offer or display for retail sale or lease, sell, lease, or transfer title to, a motor vehicle in Florida that has been tampered with in violation of this section, as determined pursuant to subsection (7). Tampering is defined as the dismantling, removal, or rendering ineffective of any air pollution control device or system which has been installed on a motor vehicle by the vehicle manufacturer except to replace such device or system with a device or system equivalent in design and function to the part that was originally installed on the motor vehicle. All motor vehicles sold, reassigned, or traded to a licensed motor vehicle dealer are exempt from this paragraph.
(b)?At the time of sale, lease, or transfer of title of a motor vehicle, the seller, lessor, or transferor shall certify in writing to the purchaser, lessee, or transferee that the air pollution control equipment of the motor vehicle has not been tampered with by the seller, lessor, or transferor or their agents, employees, or other representatives. A licensed motor vehicle dealer shall also visually observe those air pollution control devices listed by department rule pursuant to subsection (7), and certify that they are in place, and appear properly connected and undamaged. Such certification shall not be deemed or construed as a warranty that the pollution control devices of the subject vehicle are in functional condition, nor does the execution or delivery of this certification create by itself grounds for a cause of action between the parties to this transaction.
(c)?All motor vehicles sold, reassigned, or traded by a licensed motor vehicle dealer to a licensed motor vehicle dealer, all new motor vehicles subject to certification under s. 207, Clean Air Act, 42 U.S.C. s. 7541, and all lease agreements for 30 days or less are exempt from this subsection. Also exempt from this subsection are sales of motor vehicles for salvage purposes only.
(2)?No person shall operate any gasoline-powered motor vehicle, except a motorcycle, moped, scooter, or an imported nonconforming motor vehicle which has received a one-time exemption from federal emission control requirements under 40 C.F.R. 85, subpart P, on the public roads and streets of this state which emits visible emissions from the exhaust pipe for more than a continuous period of 5 seconds, and no person shall operate on the public roads or streets of this state any motor vehicle that has been tampered with in violation of this section, as determined pursuant to subsection (7).
(3)?No person shall operate on the public roads or streets of this state any diesel-powered motor vehicle which emits visible emissions from the exhaust pipe for more than a continuous period of 5 seconds, except during engine acceleration, engine lugging, or engine deceleration.
(4)?This section shall be enforced by the Department of Environmental Protection and any law enforcement officer of this state as defined in s. 112.531.
(5)?Any person who knowingly and willfully violates subsection (1) shall be punished as follows:
(a)?For a first violation, violators shall be guilty of a misdemeanor of the second degree, punishable as provided in s. 775.082 or s. 775.083, except that a motor vehicle dealer shall be guilty of a misdemeanor of the first degree, punishable as provided in s. 775.082 or s. 775.083.
(b)?For a second or subsequent offense, violators, including motor vehicle dealers, shall be guilty of a misdemeanor of the first degree, punishable as provided in s. 775.082 or s. 775.083. In addition, the Department of Highway Safety and Motor Vehicles may temporarily or permanently revoke or suspend the motor vehicle dealer license authorized pursuant to the provisions of s. 320.27.
(6)?Except as provided in subsection (5), any person who violates subsection (1), subsection (2), or subsection (3) shall be charged with a noncriminal traffic infraction, punishable as a nonmoving violation as provided in chapter 318. However, the penalty may be reduced if the person committing the violation corrects the violation pursuant to the provisions of s. 316.6105.
(7)?The Department of Environmental Protection shall adopt rules that define the specific wording of the required certification and the circumstances under which the certificate is not required. In addition, the department shall adopt rules as necessary to conform to requirements of federal law, to establish procedures to determine compliance with this section, including specifying what tampering activities constitute a violation of this section, and to provide for exceptions and waivers. For those rules applicable pursuant to subsection (1) to licensed motor vehicle dealers for certification by visual observation, the air pollution control devices or systems that shall be included in such certification for motor vehicles dated model year 1981 or later are the catalytic converter, fuel inlet restrictor, unvented fuel cap, exhaust gas recirculation system (EGR), air pump and/or air injector system (AIS), and fuel evaporative emissions system (EVP). The department may by rule remove or add devices or systems to this test if justified by developments in air pollution control technology or changes in federal law.
History.—s. 18, ch. 88-129; s. 5, ch. 89-212; ss. 6, 9, ch. 90-290; s. 5, ch. 93-19; s. 137, ch. 94-356; s. 32, ch. 96-350; s. 206, ch. 99-248; s. 33, ch. 2000-266.
316.294?Mirrors.—Every vehicle, operated singly or when towing any other vehicle, shall be equipped with a mirror so located as to reflect to the driver a view of the highway for a distance of at least 200 feet to the rear of the motor vehicle. A violation of this section is a noncriminal traffic infraction, punishable as a nonmoving violation as provided in chapter 318.
History.—s. 1, ch. 71-135; s. 1, ch. 76-31; s. 207, ch. 99-248.
Note.—Former s. 316.273.
316.2952?Windshields; requirements; restrictions.—
(1)?A windshield in a fixed and upright position, which windshield is equipped with safety glazing as required by federal safety-glazing material standards, is required on every motor vehicle which is operated on the public highways, roads, and streets, except on a motorcycle or implement of husbandry.
(2)?A person shall not operate any motor vehicle on any public highway, road, or street with any sign, sunscreening material, product, or covering attached to, or located in or upon, the windshield, except the following:
(a)?A certificate or other paper required to be displayed by law.
(b)?Sunscreening material along a strip at the top of the windshield, so long as such material is transparent and does not encroach upon the driver's direct forward viewing area as more particularly described and defined in Federal Motor Vehicle Safety Standards No. 205 as the AS/1 portion of the windshield.
(c)?A device, issued by a governmental entity as defined in s. 334.03, or its designee, for the purpose of electronic toll payments.
(d)?A global positioning system device or similar satellite receiver device which uses the global positioning system operated pursuant to 10 U.S.C. s. 2281 for the purpose of obtaining navigation or routing information while the motor vehicle is being operated.
(3)?The windshield on every motor vehicle shall be equipped with a device for cleaning rain, snow, or other moisture from the windshield, which device shall be constructed as to be controlled or operated by the driver of the vehicle.
(4)?Every windshield wiper upon a motor vehicle shall be maintained in good working order.
(5)?Grove equipment, including "goats," "highlift-goats," grove chemical supply tanks, fertilizer distributors, fruit-loading equipment, and electric-powered vehicles regulated under the provisions of s. 316.267, are exempt from the requirements of this section. However, such electric-powered vehicles shall have a windscreen approved by the department sufficient to give protection from wind, rain, or insects, and such windscreen shall be in place whenever the vehicle is operated on the public roads and highways.
(6)?A former military vehicle is exempt from the requirements of this section if the department determines that the exemption is necessary to maintain the vehicle's accurate military design and markings. However, whenever the vehicle is operating on the public roads and highways, the operator and passengers must wear eye-protective devices approved by the department. For purposes of this subsection, "former military vehicle" means a vehicle, including a trailer, regardless of the vehicle's size, weight, or year of manufacture, that was manufactured for use in any country's military forces and is maintained to represent its military design and markings accurately.
(7)?A violation of this section is a noncriminal traffic infraction, punishable as a nonmoving violation as provided in chapter 318.
History.—s. 1, ch. 84-296; s. 15, ch. 93-164; s. 208, ch. 99-248; s. 1, ch. 2003-286; s. 1, ch. 2005-47; s. 8, ch. 2010-223.
316.515?Maximum width, height, length.—
(1)?WIDTH LIMITATION.—The total outside width of any vehicle or the load thereon may not exceed 102 inches, exclusive of safety devices determined by the department to be necessary for the safe and efficient operation of motor vehicles. The use of public roads that do not have at least one through lane of 12 feet or more in width in each direction, and the use of public roads deemed unsafe for wider vehicles on the basis of safety and engineering analyses, by vehicles exceeding 96 inches in width may be restricted by the Department of Transportation or by local officials for streets and roads under their respective jurisdictions. The total outside width of a noncommercial travel trailer, camping trailer, truck camper, motor home, or private motor coach as defined in s. 320.01 may be more than 102 inches if:
(a)?The excess width is attributable to appurtenances that do not extend beyond the exterior rearview mirrors installed on the motor home by the manufacturer or the exterior rearview mirrors of the tow vehicle; and
(b)?The exterior rearview mirrors only extend the distance necessary to provide the appropriate field of view for the vehicle before the appurtenances are attached.
(2)?HEIGHT LIMITATION.—No vehicle may exceed a height of 13 feet 6 inches, inclusive of load carried thereon. However, an automobile transporter may measure a height not to exceed 14 feet, inclusive of the load carried thereon.
(3)?LENGTH LIMITATION.—Except as otherwise provided in this section, length limitations apply solely to a semitrailer or trailer, and not to a truck tractor or to the overall length of a combination of vehicles. No combination of commercial motor vehicles coupled together and operating on the public roads may consist of more than one truck tractor and two trailing units. Unless otherwise specifically provided for in this section, a combination of vehicles not qualifying as commercial motor vehicles may consist of no more than two units coupled together; such nonqualifying combination of vehicles may not exceed a total length of 65 feet, inclusive of the load carried thereon, but exclusive of safety and energy conservation devices approved by the department for use on vehicles using public roads. Notwithstanding any other provision of this section, a truck tractor-semitrailer combination engaged in the transportation of automobiles or boats may transport motor vehicles or boats on part of the power unit; and, except as may otherwise be mandated under federal law, an automobile or boat transporter semitrailer may not exceed 50 feet in length, exclusive of the load; however, the load may extend up to an additional 6 feet beyond the rear of the trailer. The 50-feet length limitation does not apply to non-stinger-steered automobile or boat transporters that are 65 feet or less in overall length, exclusive of the load carried thereon, or to stinger-steered automobile or boat transporters that are 75 feet or less in overall length, exclusive of the load carried thereon. For purposes of this subsection, a "stinger-steered automobile or boat transporter" is an automobile or boat transporter configured as a semitrailer combination wherein the fifth wheel is located on a drop frame located behind and below the rearmost axle of the power unit. Notwithstanding paragraphs (a) and (b), any straight truck or truck tractor-semitrailer combination engaged in the transportation of horticultural trees may allow the load to extend up to an additional 10 feet beyond the rear of the vehicle, provided said trees are resting against a retaining bar mounted above the truck bed so that the root balls of the trees rest on the floor and to the front of the truck bed and the tops of the trees extend up over and to the rear of the truck bed, and provided the overhanging portion of the load is covered with protective fabric.
(a)?Straight trucks.—No straight truck may exceed a length of 40 feet in extreme overall dimension, exclusive of safety and energy conservation devices approved by the department for use on vehicles using public roads. A straight truck may tow no more than one trailer, and such trailer may not exceed a length of 28 feet. However, such trailer limitation does not apply if the overall length of the truck-trailer combination is 65 feet or less, including the load thereon. Notwithstanding any other provisions of this section, a truck-trailer combination engaged in the transportation of boats, or boat trailers whose design dictates a front-to-rear stacking method shall not exceed the length limitations of this paragraph exclusive of the load; however, the load may extend up to an additional 6 feet beyond the rear of the trailer.
(b)?Semitrailers.—
1.?A semitrailer operating in a truck tractor-semitrailer combination may not exceed 48 feet in extreme overall outside dimension, measured from the front of the unit to the rear of the unit and the load carried thereon, exclusive of safety and energy conservation devices approved by the department for use on vehicles using public roads, unless it complies with subparagraph 2. A semitrailer which exceeds 48 feet in length and is used to transport divisible loads may operate in this state only if issued a permit under s. 316.550 and if such trailer meets the requirements of this chapter relating to vehicle equipment and safety. Except for highways on the tandem trailer truck highway network, public roads deemed unsafe for longer semitrailer vehicles or those roads on which such longer vehicles are determined not to be in the interest of public convenience shall, in conformance with s. 316.006, be restricted by the Department of Transportation or by the local authority to use by semitrailers not exceeding a length of 48 feet, inclusive of the load carried thereon but exclusive of safety and energy conservation devices approved by the department for use on vehicles using public roads. Truck tractor-semitrailer combinations shall be afforded reasonable access to terminals; facilities for food, fuel, repairs, and rest; and points of loading and unloading.
2.?A semitrailer which is more than 48 feet but not more than 53 feet in extreme overall outside dimension, as measured pursuant to subparagraph 1., may operate on public roads, except roads on the State Highway System which are restricted by the Department of Transportation or other roads restricted by local authorities, if:
a.?The distance between the kingpin or other peg that locks into the fifth wheel of a truck tractor and the center of the rear axle or rear group of axles does not exceed 41 feet, or, in the case of a semitrailer used exclusively or primarily to transport vehicles in connection with motorsports competition events, the distance does not exceed 46 feet from the kingpin to the center of the rear axles; and
b.?It is equipped with a substantial rear-end underride protection device meeting the requirements of 49 C.F.R. s. 393.86, "Rear End Protection."
(c)?Tandem trailer trucks.—
1.?Except for semitrailers and trailers of up to 281/2 feet in length which existed on December 1, 1982, and which were actually and lawfully operating on that date, no semitrailer or trailer operating in a truck tractor-semitrailer-trailer combination may exceed a length of 28 feet in extreme overall outside dimension, measured from the front of the unit to the rear of the unit and the load carried thereon, exclusive of safety and energy conservation devices approved by the Department of Transportation for use on vehicles using public roads.
2.?Tandem trailer trucks conforming to the weight and size limitations of this chapter and in immediate transit to or from a terminal facility as defined in this chapter may operate on the public roads of this state except for residential neighborhood streets restricted by the Department of Transportation or local jurisdictions. In addition, the Department of Transportation or local jurisdictions may restrict these vehicles from using streets and roads under their maintenance responsibility on the basis of safety and engineering analyses, provided that the restrictions are consistent with the provisions of this chapter. The Department of Transportation shall develop safety and engineering standards to be used by all jurisdictions when identifying public roads and streets to be restricted from tandem trailer truck operations.
3.?Except as otherwise provided in this section, within 5 miles of the Federal National Network for large trucks, tandem trailer trucks shall be afforded access to terminals; facilities for food, fuel, repairs, and rest; and points of loading and unloading.
4.?Notwithstanding the provisions of any general or special law to the contrary, all local system tandem trailer truck route review procedures must be consistent with those adopted by the Department of Transportation.
5.?Tandem trailer trucks employed as household goods carriers and conforming to the weight and size limitations of this chapter shall be afforded access to points of loading and unloading on the public streets and roads of this state, except for streets and roads that have been restricted from use by such vehicles on the basis of safety and engineering analyses by the jurisdiction responsible for maintenance of the streets and roads.
(d)?Maxi-cube vehicles.—Maxi-cube vehicles shall be allowed to operate on routes open to tandem trailer trucks under the same conditions applicable to tandem trailer trucks as specified by this section.
(4)?LOAD EXTENSION LIMITATION.—The load upon any vehicle operated alone, or the load upon the front vehicle of a combination of vehicles, may not extend more than 3 feet beyond the front wheels of the vehicle or the front bumper of the vehicle if it is equipped with a bumper.
(a)?The limitations of this subsection do not apply to bicycle racks carrying bicycles on public sector transit vehicles.
(b)?The provisions of this subsection shall not apply to a front-end loading collection vehicle, when:
1.?The front-end loading mechanism and container or containers are in the lowered position;
2.?The vehicle is engaged in collecting solid waste or recyclable or recovered materials;
3.?The vehicle is being operated at speeds less than 20 miles per hour with the vehicular hazard-warning lights activated; and
4.?The extension does not exceed 8 feet 6 inches.
(5)?IMPLEMENTS OF HUSBANDRY AND FARM EQUIPMENT; AGRICULTURAL TRAILERS; FORESTRY EQUIPMENT; SAFETY REQUIREMENTS.—
(a)?Notwithstanding any other provisions of law, straight trucks, agricultural tractors, and cotton module movers, not exceeding 50 feet in length, or any combination of up to and including three implements of husbandry, including the towing power unit, and any single agricultural trailer with a load thereon or any agricultural implements attached to a towing power unit, or a self-propelled agricultural implement or an agricultural tractor, is authorized for the purpose of transporting peanuts, grains, soybeans, cotton, hay, straw, or other perishable farm products from their point of production to the first point of change of custody or of long-term storage, and for the purpose of returning to such point of production, or for the purpose of moving such tractors, movers, and implements from one point of agricultural production to another, by a person engaged in the production of any such product or custom hauler, if such vehicle or combination of vehicles otherwise complies with this section. The Department of Transportation may issue overlength permits for cotton module movers greater than 50 feet but not more than 55 feet in overall length. Such vehicles shall be operated in accordance with all safety requirements prescribed by law and rules of the Department of Transportation.
(b)?Notwithstanding any other provision of law, equipment not exceeding 136 inches in width and not capable of speeds exceeding 20 miles per hour which is used exclusively for harvesting forestry products is authorized for the purpose of transporting equipment from one point of harvest to another point of harvest, not to exceed 10 miles, by a person engaged in the harvesting of forestry products. Such vehicles must be operated during daylight hours only, in accordance with all safety requirements prescribed by s. 316.2295(5) and (6).
(c)?The width and height limitations of this section do not apply to farming or agricultural equipment, whether self-propelled, pulled, or hauled, when temporarily operated during daylight hours upon a public road that is not a limited access facility as defined in s. 334.03(13), and the width and height limitations may be exceeded by such equipment without a permit. To be eligible for this exemption, the equipment shall be operated within a radius of 50 miles of the real property owned, rented, or leased by the equipment owner. However, equipment being delivered by a dealer to a purchaser is not subject to the 50-mile limitation. Farming or agricultural equipment greater than 174 inches in width must have one warning lamp mounted on each side of the equipment to denote the width and must have a slow-moving vehicle sign. Warning lamps required by this paragraph must be visible from the front and rear of the vehicle and must be visible from a distance of at least 1,000 feet.
(d)?The operator of equipment operated under this subsection is responsible for verifying that the route used has adequate clearance for the equipment.
(6)?TOUR TRAINS.—Any tour train or similar operation which has been continuously conducted for 120 days prior to the date this chapter becomes law is also authorized hereunder, subject to the length restriction and other restrictions imposed by law, not in conflict with the provisions of this chapter.
(7)?FIRE OR EMERGENCY VEHICLES, UTILITY VEHICLES, AND OTHER VEHICLES TRANSPORTING NONDIVISIBLE LOADS.—The length limitations imposed by this section do not apply to:
(a)?Vehicles of a fire department or emergency vehicles owned or operated by governmental entities.
(b)?Utility vehicles owned or operated by governmental entities or public utility corporations, or operated under contract with such entities or corporations:
1.?When transporting poles during daytime, except on weekends and holidays, as defined in the rules of the Department of Transportation, and when the vehicle and load do not exceed 120 feet in overall length, provided proper flags are located at the rearmost end of the load. However, such movements with an overall length in excess of 75 feet:
a.?Shall be equipped with a working warning light device.
b.?Shall be accompanied by a company-provided flasher-equipped escort vehicle when making turns within corporate city limits.
2.a.?When transporting poles during nighttime and when the vehicle and load do not exceed 120 feet in overall length. Such movements shall be equipped with a working warning light device and shall be accompanied by one leading and one trailing company-provided flasher-equipped escort vehicle.
b.?The provisions of sub-subparagraph a. notwithstanding, for vehicles and loads with overall lengths not exceeding 85 feet and being transported under emergency conditions, only a single trailing company-owned flasher-equipped escort vehicle shall be required, provided that the pole being transported shall be equipped with active marker lights, visible from both sides, at a maximum of 6-foot intervals mounted along the pole or trailer extending the length of the trailer and at 36-inch intervals along the pole extending beyond the rear of the trailer.
3.?When transporting poles during emergencies or required maintenance. Such movements may be made on all days and at all hours, provided the respective daytime or nighttime requirements are otherwise met.
4.?When operating flasher-equipped straight truck utility vehicles that have permanently mounted equipment that extends up to 9 feet beyond the front bumper, provided:
a.?Such equipment, when in the travel position, is supported in such a manner that it has a minimum of 80 inches clearance above the roadway;
b.?Such equipment is illuminated on the forwardmost sides with high visibility reflective tape;
c.?The respective daytime and nighttime requirements for operation are otherwise met;
d.?Nighttime emergency or required maintenance operation of such utility vehicles with overall lengths in excess of 50 feet are led by a company-provided flasher-equipped escort vehicle; and
e.?Trailers are not pulled by utility vehicles over 50 feet in length.
A flasher-equipped escort vehicle is defined as an automobile or truck that closely accompanies an over dimensional vehicle or load carried thereon to alert approaching traffic of that vehicle or load. Such escort vehicles shall be equipped with a working warning light device, as defined in this subsection, except that such device shall be located on top of the escort vehicle. Warning light devices required in this subsection shall be consistent with size, color, type, intensity, and mounting requirements developed by the Department of Transportation.
(c)?Truck tractor-semitrailer or pole trailer combination vehicles transporting poles or other objects of a structural nature that cannot be readily dismembered, when operating in the daytime, excluding Saturdays, Sundays, and holidays and when the vehicle and load do not exceed 75 feet when proper flags are displayed as required in s. 316.228.
(d)?Vehicles transporting tree-length unprocessed logs, when operating in the daytime and when the vehicle and load do not exceed 75 feet; but, in respect to such movement, proper flags shall be located at the extreme ends of the load.
(e)?Straight trucks transporting poles or other objects of a structural nature that cannot be readily dismembered, when operating in the daytime, excluding Saturdays, Sundays, and holidays, when the load does not extend past the rearmost part of the vehicle more than one-half the length of the permanent bed or cargo-carrying structure of the vehicle, when at least two-thirds of the length of the cargo rests on the bed or cargo-carrying structure, when the load complies with subsection (4), and when proper flags are displayed in accordance with s. 316.228.
(8)?WRECKERS.—The limitations imposed by this section do not apply to a combination of motor vehicles consisting of a wrecker licensed in accordance with s. 320.08(5)(d) or (e) and a disabled motor vehicle, trailer, semitrailer, or tractor-trailer combination, or a replacement motor vehicle, which is under tow by the wrecker, if the size and weight of the towed vehicle is consistent with statutory requirements and the requirements of this subsection.
(a)?The limitations imposed by this section do not apply to a combination of motor vehicles consisting of a wrecker licensed under the International Registration Plan and a disabled motor vehicle, trailer, semitrailer, tractor-trailer combination, or a replacement motor vehicle, which is under tow by the wrecker, if the size and weight of the towed vehicle is consistent with statutory requirements and the requirements of this subsection.
(b)?However, a wrecker may not tow a disabled nonconforming vehicle operating under a current special use permit or permits where the combined weight of the wrecker and the towed nonconforming vehicle exceeds the permitted weight of the towed vehicle's permit.
(c)?Where the combined weight of the wrecker and the towed vehicle exceeds the maximum weight limits as established by s. 316.535, the wrecker must be operating under a current wrecker special use permit or permits as provided in s. 316.550(5) or in accordance with paragraph (b).
(d)?The limitations imposed by this section do not apply to a combination of motor vehicles consisting of a wrecker licensed in accordance with s. 320.08(5)(d) or (e) and a nondisabled tractor-trailer combination that is under tow by the wrecker, if the tractor-trailer combination is being towed by the wrecker in an emergency situation as directed by a law enforcement officer. No wrecker shall tow a nondisabled tractor-trailer combination except in an emergency situation as directed by a law enforcement officer, or as provided in s. 715.07.
(9)?BUSES AND PRIVATE MOTOR COACHES.—
(a)?Anything in this chapter to the contrary notwithstanding, no bus or private motor coach may exceed a length of 50 feet, for a single-unit coach, or 65 feet, for an articulated coach. No bus or private motor coach may exceed a width of 102 inches, exclusive of safety equipment.
(b)?School buses which are subject to the provisions of s. 316.615 or chapter 1006 are exempt from the provisions of this subsection.
(10)?AUTOMOBILE TOWAWAY AND DRIVEAWAY OPERATIONS.—An automobile towaway or driveaway operation transporting new or used trucks may use what is known to the trade as "saddle mounts" if the overall length does not exceed 97 feet and no more than three saddle mounts are towed. Such combinations may include one full mount. Saddle mount combinations must also comply with the applicable safety regulations in 49 C.F.R. s. 393.71.
(11)?REFUSE COLLECTION AND TRANSPORT VEHICLES.—A combination of vehicles up to five in number is authorized for the sole purpose of collecting refuse and transporting refuse to a dump. Such a vehicle or combination of vehicles shall be covered in such a manner that refuse transported therein does not spill from the vehicles, shall otherwise comply with the provisions of this section, and shall use the state roads only to the extent necessary to collect and dispose of refuse.
(12)?TURNPIKE LIMITATIONS.—The adopted vehicle width, height, and length rules of the Florida Turnpike are in addition to the requirements of this section. Vehicles seeking to operate on the turnpike shall meet the requirements of the rules adopted by the Department of Transportation for the turnpike.
(13)?MAINTENANCE EQUIPMENT.—The vehicular dimensional limitations imposed by this section do not apply to equipment owned or operated by the Department of Transportation when performing maintenance operations on public roads during daylight hours. However, such equipment shall be operated in accordance with all safety requirements prescribed by law and Department of Transportation rules.
(14)?MANUFACTURED BUILDINGS.—The Department of Transportation may, in its discretion and upon application and good cause shown therefor that the same is not contrary to the public interest, issue a special permit for truck tractor-semitrailer combinations where the total number of overwidth deliveries of manufactured buildings, as defined in s. 553.36(13), may be reduced by permitting the use of an overlength trailer of no more than 54 feet.
(15)?MOTOR HOMES.—No motor home may exceed a length of 45 feet exclusive of bumpers and safety devices.
History.—s. 1, ch. 71-135; s. 1, ch. 74-117; s. 1, ch. 76-31; s. 4, ch. 79-99; ss. 3, 7, ch. 81-209; s. 3, ch. 83-298; s. 1, ch. 84-122; s. 2, ch. 85-81; s. 80, ch. 85-180; s. 3, ch. 85-343; s. 1, ch. 86-230; s. 8, ch. 86-243; s. 1, ch. 86-260; s. 1, ch. 86-282; s. 6, ch. 88-215; s. 3, ch. 88-246; s. 64, ch. 89-282; s. 1, ch. 89-320; s. 2, ch. 90-200; s. 4, ch. 91-418; s. 1, ch. 93-33; s. 4, ch. 95-247; s. 1, ch. 97-58; s. 9, ch. 97-280; s. 33, ch. 97-300; ss. 15, 16, ch. 2000-313; s. 41, ch. 2002-1; ss. 5, 69, ch. 2002-20; s. 11, ch. 2002-295; s. 957, ch. 2002-387; s. 15, ch. 2003-286; s. 11, ch. 2004-257; s. 19, ch. 2006-290; s. 13, ch. 2007-55; s. 1, ch. 2008-236; s. 11, ch. 2010-225.
Note.—Former s. 316.196.
Now we're getting somewhere:
320.0863?Custom vehicles and street rods; registration and license plates.—
(1)?As used in this section, the term:
(a)?"Blue dot tail light" means a red lamp that contains a blue or purple insert that is not more than one inch in diameter and is installed in the rear of a motor vehicle.
(b)?"Custom vehicle" means a motor vehicle that:
1.?Is 25 years old or older and of a model year after 1948 or was manufactured to resemble a vehicle that is 25 years old or older and of a model year after 1948; and
2.?Has been altered from the manufacturer's original design or has a body constructed from nonoriginal materials.
(c)?"Street rod" means a motor vehicle that:
1.?Is of a model year of 1948 or older or was manufactured after 1948 to resemble a vehicle of a model year of 1948 or older; and
(2)?The model year and year of manufacture which the body of a custom vehicle or street rod resembles is the model year and year of manufacture listed on the certificate of title, regardless of when the vehicle was actually manufactured.
(3)?To register a street rod or custom vehicle, the owner shall apply to the department by submitting a completed application form and providing:
(a)?The license tax prescribed by s. 320.08(2)(a) and a processing fee of $3;
(b)?A written statement that the vehicle will not be used for general daily transportation but will be maintained for occasional transportation, exhibitions, club activities, parades, tours, or other functions of public interest and similar uses; and
(c)?A written statement that the vehicle meets state equipment and safety requirements for motor vehicles. However, the vehicle must meet only the requirements that were in effect in this state as a condition of sale in the year listed as the model year on the certificate of title.
(4)?The registration numbers and special license plates assigned to such vehicles shall run in a separate series, commencing with "Custom Vehicle 1" or "Street Rod 1," respectively, and the plates shall be of a distinguishing color and design.
(5)(a)?A vehicle registered under this section is exempt from any law or local ordinance that requires periodic vehicle inspections or the use and inspection of emission controls.
(b)?Such vehicle may also be equipped with blue dot tail lights for stop lamps, rear turning indicator lamps, rear hazard lamps, and rear reflectors.
patooyee said:
The form you linked to on pirate is to get a title on the junk / scrap vehicle, correct? Once that is in hand you then register how?
I need to look again and make sure I linked the right form, but I'm pretty sure I did. It should apply to "custome or rebuilt vehicles meeting the criteria you listed above Keep in mind I am also former law enforcement so the process might have been easier for me. Basically you find a rotted vehicle with a clear title and VIN. You then build a new vehicle (your buggy) and say you are "rebuilding" the rotted vehicle to it. You have law enforcement come out, they inspect the old vehicle, the new "rebuilt" vehicle, and sign your affidavit. You go to the DMV with your new "rebuilt" vehicle and they issue a new VIN for it. It may be different in your local tax collector's office, or because you're not law enforcement, but I literally handed them my paperwork, and the inspector came out to the parking lot, affixed the sticker containing the new VIN, and I was on my way..
That was the wrong form.. I'll try to get the right one for you when I get some time to look
Holy Waay to much to read batman, i'm guessing it has a lot to do with where you live, The retarded cops around here would probably pull you over just to check it out if a full buggy came Rollin down the road .. I've driven my around a few times, I havent got a tag yet so don't go far, definitely would not get on I 20, or far from house and run out of pane. The back roads and stuff is fun, ESP with my lil girl.. Man patooyee now that you mentioned it , those times are as good as it dam gets.. Makes me think, I'm gonna start askin my oldest daughter to Be my "co driver" a lot more ... Glad I read this bud.
I have regular steering streached and 4 link rear on c/o leafs up front running DIY beadlock wheels and 37 bi ply iroks, I drive this jeep alot on the road and never had any issues here in KY it is not super fast or loud but it does cruise at 60 mph on the 4 lane driving it one handed love driving it
Up here in Indiana they dont mess with us at all. I drive mine all over with 42s, full hydro and no flairs. I even cruse around town with no windshield half the time. when ever I see a cop I just wave and dont act stupid. I even drove mine 70 miles to work and back from north of Indy to the east side down the hwy at 65mph.
Mall crawlin (wife is trying to get the dirt off her purse)
Street legal in alabama jk on 42s and racelines full hyrdro ori struts and a blown 6.0L drive this thing all over. put 2k road miles on it.
Street Legal in TN Willys buggy
With the picture of the yota you posted Pat, id say no problem. the taco i was referring to earlier doesn't look much different, just got the thin plexi for a windshield. None of the rails running around have windshields in them, most are riding around with just a pair of sunglasses and flipflops on. I ride around without the window frame on my scrambler quite a bit and have been hassled more times with the frame and broken windshield on then i have been without it attached.
Re: Re: How far can you push "street legal?" (Pics of you have them.)
Here is my street legal buggy (KY)
Regerstered it as a dune buggy. Had it inspected and filed the paper work for a Vin #. Installed the Vin # and had to take it back for a final inspection which was only to make sure the Vin was attached properly. County clerks office Regerstered it and issued a license plate for it. Progressive insures it.
