zjtrey
clemsonjeep said:I've been planning to pick up all the parts I'll need to simplify my wiring and dash setup, but I haven't found a great place to get everything from. Which vendors are ya'll using to buy the toggles with rubber boots, IGN start buttons, battery switches, miniature led indicators, relays, fuse panels etc? I plan to put all of this on a single panel with the fuse panel and all of that attached to back side.
I'm a fan of snagging the relays at the salvage yard...and will probably do that, but I just don't feel like I've located a source that carries the majority of the pieces...at a reasonable cost. Places like speedwaymotors.com sell toggles for $9.99...way too high and places like surpluscenter.com sell them for less than $2 each. Let me know who ya'll have used with good results...any particular brands of switches?
I haven't located a good "all around" supplier for this stuff so I always end up buying from several different place to get what I need at the best price.. this is a slow process by the time you make sure you're comparing apples to apples and consider shipping charges..
thing is everyone has different preferences on what components to use…
I like using the carling rocker switches.. these guys have a good selection and some snazzy covers at decent prices, http://www.otrattw.com most of these switches will handle 35-40 amps continuous so you can run fewer relays if you like it that way..
I recently discovered that Oreilly has a good selection of fuse blocks in their special order catalog, I got a 12 circuit block with ground buss for $20ish… everywhere else I've shopped was more expensive and this unit was made way better than any of the cooper products i've used in the past..
