grcthird
Birmingham, AL
Vacuum filler tool makes this all day jack the buggy up and screw with it to get bled thing a less than 5 minute process. After buying one I never fill any cooling system with out using it.
redneckengineered said:This is gonna blow y'alls minds but I run my buggy with all the steam ports blocked and it never overheats. Did it in a pinch to get running years ago when the buggy was new and never had the need to change it. That being said, go ahead and plumb it into the water pump there as that is a good way to do it. No need running it back all the way to the radiator. Have you tried calling Adam? He built your chassis and knows all the tricks for getting the air out. I know when he fills the system at his shop he uses a vacuum pump.
grcthird said:Vacuum filler tool makes this all day jack the buggy up and screw with it to get bled thing a less than 5 minute process. After buying one I never fill any cooling system with out using it.
I believe I have nearly all of the air out now. I used a vacuum pump and filled every hole I could find the first time I fired her up and it took a little time but got never had a cooling problem until I had the nose in the air for while. I have the same bigass Griffin radiator and WOD AN thermostat housinhg as you. It probably won't ever give me any trouble again but I have the T style steam port kit as well as a bleeder valve for the water pump on the way for good insurance.redneckengineered said:This is gonna blow y'alls minds but I run my buggy with all the steam ports blocked and it never overheats. Did it in a pinch to get running years ago when the buggy was new and never had the need to change it. That being said, go ahead and plumb it into the water pump there as that is a good way to do it. No need running it back all the way to the radiator. Have you tried calling Adam? He built your chassis and knows all the tricks for getting the air out. I know when he fills the system at his shop he uses a vacuum pump.
