TacomaJD
I LIKE CHEAP STUFF.....
Alright thanks a lot! We'll be rolling in around noon Friday, I'm pumped about this ride!
JohnG said:Getting loaded up.![]()
WHIZARD said:I'll be rolling in around 11 Friday. My entire crew backed out on me so if I can fall in with anyone on the trails that would be awesome. I'll be in a blue hooded sammi buggy.
TacomaJD said:They'll be plenty of us there to wheel with, just join in and follow whoever you can.
Y'all got a jump on me. I still gotta swap out coil springs on my coilovers, pickup a set of tires I'm bringing for someone, fill propane, load up, and pack everything. Fawk 2nd shift.
LandSpeeder said:You mind throwing a cone or two on the spot behind you for me?! Same one I got on that one time.
The other week I had to have a "back in" spot and it kinda brought the suck.
LandSpeeder said:Shunt. I have a U=joint to change out on the motor-house!
May grease the current one and just stay at 60mph...
I think I'ma "passenger" it this weekend! I prefer riding shot gun and yelling anyway.
JohnG said:I will, but if someone says they have it reserved, then you are on your own. Trying to remember the exact site you had. Same side of road as me but behind. Not the one straight back on the other side of the road with the porch swing. Both sites are beach front and close to the pool.![]()
4byfan said:I've rode with Steve in the green yota. Triple cases with a 4.7 in one. Hell of a crawl ratio.
LandSpeeder said:Well, that's just it, they told me last time it's "First come first serve" and there is zero reservations on spots...
Folks were CAMPING in the good spots with tents... since they paid for power spots with water by the time I got there.
In my opinion... that's a rule that should be adjusted. I'm too big for most of those spots, and that means you are too.
No worries either way, but DEFINITELY not the spot over looking the hill. I need as much flat ground as I can. I was referring to the "pull through spot" that is on the backside of the other spots.
Either way.
LandSpeeder said:I'm too big for most of those spots
rednecklights said:well, I siliconed one irok bead ... only took the better part of 2 hrs and whipped my ass. I will pay someone to do the other 3 !
Sent from my C771 using Tapatalk 2
