Hypothetical question?
Re: Re: Re: Hypothetical question?
TBItoy said:
I actually think they are more than that. $2000+ is for a LP10" 3rd...
Check out the trophy truck rearend pricing from tubeworks http://www.tubeworks.com/tt-3rd-members.html
Holy hell. So the hp 35 spline pinion gears in a stock housing is actually the next big thing. **** yeah glad I went with the chunk I did
I was going to edit my last post. But seems like the 70 gears would be a good upgrade, if start breaking 60 stuff. And it wouldn't hurt the wallet as bad if you were already running a 60.
Probably $1000-2000
~$1000 bare minimum
Gear set $500
Jana 76 bearing kit $340
35 spline yoke/flange $125 (1350 Strange)
machining your existing Dana 60 spool (or buying a D70 carrier) ??? according to your hook up on machine work.
TBItoy said:
Isn't the cheapest HP10" dropout $2500? + Housing
No doubt the OEM 10" gears or the D60 35 spline pinion gears are going to be the most cost effective.
I'd drop one of those in and mash my motor till it broke
Gear Works Hi-10's are $3K +
