CHOP SHOP
If you are going to back up a lunchbox style locker, please tell us what you run for axles.
If you not killing axles then that explains why the locker is fine too.
If you are killing stock birfs and feel you need 30 spliners then get a detroit and stop tearing the front end apart.
I also feel the longs kill them quicker. They will twist alot of energy up untill it finnaly unlocks and BANG!!
Its not just big rigs either. My roomate runs 34s on a yota and his lunchbox busted/chipped out the pins too.
Will the lock-rite hold up to an '84 yota 4cyl with 4.56 gears and 35" tires?
I agree with the weight thing...:awesomework:
By set up properly, I mean axles centered (or at least reaaalllly close!), proper preload on carrier bearings, and that the carrier bearings go onto the carrier tight (ie: press onto the carrier, not barely, but securely as designed)---if they are loose on the carrier, this allow the carrier to 'walk' around when under load....no matter how much preload there is on the bearings.
And stock axles!!:redneck:....have a new pair of cryo'd birfs (never installed) sitting in a box for when the inevitable happens.... or I may buck up at that time for 30 spliners. The last time I had my front end apart (a yr ago when I thought the LR took a ****) the stock birfs are as smooth and tight as I have ever seen; found the carrier was toast where the bearings press onto (they fell off when I took it apart:haha; grabbed a good carrier, installed new Koyos onto it, set up a new lockrite into it, and is working just fine!!! Needless to say, the Lockrite I took out looked damn near new... I'd have installed the original LR, but since I had a new one I just installed it instead.
It's lookin' like my original LR will be going into Unc's front axle (as long as the carrier/bearings are ok...:awesomework::;
Some people can break anything but with a little careful wheeling and knowing when to back off a little you can make it survive.
Who the hell wants to do that!
There are a few people who have seen me wheel on here, ask them how I roll. I have never taken an easy line unless denied by the hardest line first. I would wheel with you (Ed) all day long no problem. And I find no fun in trying to fix my **** on the trail, I prefer to spend my day wheeling not wrenching. Some people love to brag about all the crap that they have broke, I brag about all the crap I haven't broke.
I have a Spartan in the rear of my yota. V6 engine, 4cyl third 5.29 and 37's I've daily'd my truck in city traffic on the freeway and never felt anything. Have never felt it while on pavement at all unless it's wet and I want to have fun. Works great when wheeling, have only heard the unlocking bang once but overall mine has been a very smooth locker. It is also priced with the lockrite and Aussie locker
From my experience putting a lunchbox in the rear always yields bad results, tho in the front works very well. I as well as many of my friends have ran them only in the front for years with no probs, and in a more economical build will do so again.
