Ignition help
Might be the ignition rack inside the column is cracked Trashy...this is a little potmetal piece that links the lock cylinder to the rod that goes down to the switch...pretty common....
Ahh yes, I know just the piece you are talking about. If that's the case it'll get a set of switches and I'll just bypass the fawking whole pain in the ass. :redneck:
Nope adjusting or replacing the ignition switch. If it would stay running in a better position I'd let it be but it has to be almost in the start position to keep the fuel cutoff solenoid energized.
[sarcasm] ha ha [/sarcasm]
