Is a Currie hi pinion scrap metal or do folks still run these
fourjeepin
Member
7
So I bought a Currie Ford 9" hi-pinion probably 12 years ago with the intention of building a 609 front axle for my CJ. Life got in the way and this never happened so I am curious if these are still viable for the front axle or not. I know people that tried to run them in the rear and the gears rather quickly came apart but will they hold for the front? Does anyone still run one of these?
Here is what I have:
  • Currie hi pinion case
  • Professionally installed 4.10 gears
  • 35 spline ARB
The gears are new but I do not recall the brand. The chunk and ARB were purchased used. Asking for guidance on how to price this for resale. If the case is worthless, then I can price this as a used ARB otherwise I will still sell complete, but would like to try to get a few extra dollars for the case and gears.
They take 8.8 hp gears.
It's always worth something, especially for someone who wants to build a lightweight vehicle with better axles than yota. Think samurai or single seater crew.
Yes, 8.8 gears in the 9" dropout case. I bought this setup from a guy that ran it in the rear of his Jeep (TJ I think it was). They were not designed to be run in the rear and it causes the teeth to chip. I had the gears replaced by a professional mechanic in the Renegades, a former 4WD club in the Atlanta area. I have a copy of the build sheet somewhere.
If this was yours, what would you try to get for it? If it wasn't 35 spline, I would build a 449 around it, but my Jeep rarely sees dirt these days, much less rocks.
$1k is what I was thinking as well. It would be a good deal for someone that wants to run it as is, though that is probably a small group.
