is an exo cage street legal?
My daughter is an LEO in Renton. I asked her once if she would pull someone over for not having full coverage on the tire width. Her response? Only if I needed a reason to pull them over.
I drive my wheeler with an EXO around town (a small town) but I trailer it everywhere else even with lisence, insurance, mudflaps, etc. I just dont want to push my luck... A friend of mine is a sheriff and he told me that my beadlocks were a bigger deal then my cage and bumpers but I have yet to be pulled over for them. If they "want" to find something, they will.
according to the LEOs that i've spoke with, bead locks are not illegal.
This is a mis-interpretation of multi-piece wheels.. i.e. split rims..
Dangerous mo fo's for sure
Which RCW?
I'll give it a look.
rcw 46.37.517 body and hardward. rcw 46.44.010 outside width limit. rcw 468.38.270 specialised equipment . wac 468.38.073 measurement exclusive devices. i think thers one about measurement exclusive devices in the rcw but i gotta go so ill find it later tonight
http://apps.leg.wa.gov/rcw/default.aspx?cite=46.37.517
http://apps.leg.wa.gov/rcw/default.aspx?cite=46.44.010
Your search - rcw 468.38.270 - did not match any documents.
Suggestions:
Make sure all words are spelled correctly.
Try different keywords.
Try more general keywords.
Try fewer keywords.
Your search - wac 468.38.073 - did not match any documents.
Suggestions:
Try fewer keywords.
Everything is legal its only illegal if you get caught.My dad always told me that I don't know why my mom would hit him.LOL
Split rims are still legal. So I think you are on the wrong path with this.
Home made beadlocks are illegal because it is illegal to modify a wheel without having it re-certified by the DOT. All wheels are DOT certified before they are legal for street use.
They don't actually ticket the beadlock. I received a ticket on 410 out by Little Naches and the ticket was for defective wheels. I asked the LEO about this and he explained that welding to a DOT certified wheel renders it defective and no longer legal for street use.
so could a certified welder put them on and get them reinspected by DOT n ur good?
:awesomework:
Here's the law.
RCW 46.37.369
Wheels and front suspension.
(1) No vehicle shall be equipped with wheel nuts, hub caps, or wheel discs extending outside the body of the vehicle when viewed from directly above which:
(a) Incorporate winged projections; or
(b) Constitute a hazard to pedestrians and cyclists.
For the purposes of this section, a wheel nut is defined as an exposed nut which is mounted at the center or hub of a wheel, and is not one of the ordinary hexagonal nuts which secure a wheel to an axle and are normally covered by a hub cap or wheel disc.
(2) Tire rims and wheel discs shall have no visible cracks, elongated bolt holes, or indications of repair by welding. In addition, the lateral and radial runout of each rim bead area shall not exceed one-eighth of an inch of total indicated runout.
(3) King pins or ball joints shall not be worn to the extent that front wheels tip in or out more than one-quarter of an inch at the lower edge of the tire.
[1977 ex.s. c 355
It has something to do with factory equipment and I think( it has been a few years ) ISO 17... testing of the wheel for street use. That is why you see some wheels that say " for off road use only "
Also it has something to do with OE and DOT regulations
Hope this helps. I know if I had the time I could Google it and find the exact reason
No, any backyard welder can get them certified, I will certify all your weld on beadlocks
For a large fee :redneck:
It has alot to do with federal motor vehicle safety standards 49CFR571, but they should only be applied to new vehicles, vehicles for sale, import or interstate commerce.
Once licensed, then the RCW should regulate state standards.
