Is there a better direct replacement for a 42RLE in a 06 Rubicon?
Would a 5.3/4l60/eco box crawl box thing/205 fit ?
Seems like the cheapest/best solution...?
I've priced it every different way I can think of and I always come in right around $5000-5200 with just the basics. There are always more odds and ends that you wind up needing.
The 42RLE is junk. I'm just waiting on the one in my LJ to take a dump.
Out of length on a 109" web and using all the droop in the rear with 14's and a 1410. Maybe with a 350/box/205. Still not a fan but I LOVED the 2.72 in my old buggy. Never used 5.44. I mean if that case was good enough for 40" stickies I'd just run a 241 from a 4l80. When is somebody going to make a rear case half for the 241 that is a single row of gears simply to transmit power to the front Output that also serves as a girdle and is very low profile. Countershaft pocket in front case being a large problem I'm sure. I digress.
Always have wished there were a 27spline female input for a 205 so you could drop it in a ford and run drivers drop on a 350/pg/4l60 in a short package
