It has started... SAS Dakota 1997
Not much to update yet, been busy with the house. Here are some flexy pics when I pulled it out today.
Front shot, the hood is popped so no worries about the gap ;)
Droop from the side, still using my stock brake lines.
rear side view
I had some time to work on the foo foo stuff...
Here are the rock lights with the headlights on.
And this is just the rock lights on.
no sir I have not. we bought a house and that has killed the last few months of my time. I ordered my 2nd to last round of parts so I hope to have my front axle setup and my bump stops in place to finish off the suspension. All that will be left is fabbing a crossmember, installing my SS front brake lines, and measuring and ordering my OX locker cable.
And sometime in the near future I need to get OBA and work on some sort of a cage...
Dude, I know how you feel. I thought I was the only one. My closing date on the house I just bought is Sep 1st and my wedding date is Sep 5th. It has been a crazy last few months and im about 2 orders away from having all the parts for my buggy too. Hang in there dude. :booo:
Yeah. It takes up a lot of time but it's worth it. Now I have a clean dry warm place to work on our rigs. :)
I'm hoping to get a test run in withinthe next 2 weeks.
ok so did are you running an auto trany or manual. and were you able to keep the stock tcase.
So as im nearing completion I decided to try out a 1 tire flex. This shows that the back end is way too stiff compared to those 4.5" Rubi springs. So ill be taking the rear add-a-leaf out and probably do a ubolt flip to get them threads up top. My locker cable came in yesterday so if I have time this weekend ill be pulling the axle out from under the truck for any final welding/grinding before paint, and also setup the gears and locker.
Thanks,
Im trying to get most of the bugs that ill want to change fixed before the maiden voyage in a week. so we shall see how it does..
OK so I got my front axle painted, replaced the rubber bushing on my trac bar with a urethane one, and painted my steering and trac bar. Going to finish setting up my gears today and get my driveshaft cut down and I should be ready to go wheelin! :D
Im sure ill come back with things ill want to change. Pics soon
nice rig man! i was gonna do a similar suspension setup, but i ran out of time and decided that i didnt have enough cash flow... theres always the future though...
my question is are u planning on bracing the t-case/tranny mount crossmember? to my newbish eyes, it looks kinda weak... i personally used a piece of pipe with about a 5 inch ID and 3/8 wall and cut the mount up and welded that in, then braced it, kinda over built, but wont have to fix it later....
yeah I am, that is just a temp to hold things in place. I ran out of time on some things like I dont have my rock lights done, mud flaps, didnt shorten the bed.... but for now the rig is driveable. ill be working on the brace asap.
Looks great man.
1 suggestion.
ditch the straps on your front drive shaft u-joints and get u-bolts.
straps bring the suck.. seen them break WAY too often.
If your running 1310 u-joints let me know.. I have a yoke you can HAVE.
Ive known about the straps being a weak link. I just happen to have these so I used them. Ill look around for a 1310 yoke.
I made it through my first maiden voyage with no breaks and not even a funny noise! I did discover that my steering needs an adjustment toe-in/toe-out and my OX cable need to be just a touch tighter. I have a few pics from the trip that ill try to get up soon.
Things I tested wheelin were lots of sidehilling/turning on sidehill, hillclimbs, and last but not least very STEEEP downhill descents on loose ground. These pitbulls and locker combo are amazing.
Here is a small hill climb on loose rock.
Posing in a rock pit.
Found a gravel pile to test my tires for digging.
Look at that ass...
Ill see what other pics everyone else had I just pulled these up.
