MonnlightRacing77
When in Doubt Throttle Out
Few guys around here running the 40in boss X.they all seem really happy with them
I appreciate that a lot man. I've got everything on order from Barnes that I needed. Most of which I had laying around in the shop with the exception of a couple brackets. I'll slap it together once it gets here and probably care it down to @Markrobinson to burn the brackets into the axle. I don't think my Handler 140 will do it...If you were a lot closer I have a whole set up off my Yj you could have, I kept ripping mine off the axle end #fordpower
Sure it will, just bevel your bracket and stack some passes.I appreciate that a lot man. I've got everything on order from Barnes that I needed. Most of which I had laying around in the shop with the exception of a couple brackets. I'll slap it together once it gets here and probably care it down to @Markrobinson to burn the brackets into the axle. I don't think my Handler 140 will do it...
Don't count my 4.0 short! HahaI think we originally welded mine on with the Hobart 140. It held till I got to Harlan and too many beers late at night in upper rock garden lol, then we welded it on with the stick welder at camp and when it ripped off the second time it actually tore a section out the axle tube, I'm sure with the 4.0 and auto you will be fine
Nothing wrong with a good running 4.0Don't count my 4.0 short! Haha
I keep expecting it to die. Despite the odds, it's still running strongNothing wrong with a good running 4.0![]()
Wait, I gotta do the welderin too? You better bring ol grandad or at least jimmy beam to helpI appreciate that a lot man. I've got everything on order from Barnes that I needed. Most of which I had laying around in the shop with the exception of a couple brackets. I'll slap it together once it gets here and probably care it down to @Markrobinson to burn the brackets into the axle. I don't think my Handler 140 will do it...
Nah. I just need use of the welderer. I'll do the burnin!Wait, I gotta do the welderin too? You better bring ol grandad or at least jimmy beam to help
It absolutely did on that Return trip! Carried back all our camping gear, an LS motor motor for @whiskeymakin and 4 43's. Towed smooth as could be. I monitored up mont eagle again. Started the mountain at 197*. 201* at the top. And that includes getting cut off and slowed down fo 45ish then speeding back up to 70. I might look into adding air bags before I hookup my 45' gooseneck.Boy that onetondra sure has the squat![]()
This was my first trip pulling with a WDH and even Brittany noticed it pulled smoother. No bounce between the trailer and truck. Other than the obvious higher RPMs, it really felt like there was nothing behind me.It absolutely did on that Return trip! Carried back all our camping gear, an LS motor motor for @whiskeymakin and 4 43's. Towed smooth as could be. I monitored up mont eagle again. Started the mountain at 197*. 201* at the top. And that includes getting cut off and slowed down fo 45ish then speeding back up to 70. I might look into adding air bags before I hookup my 45' gooseneck.![]()
Fixed it for yaMmmmm ... non sticky mud whompers
