Leaky Seals! Help please
Its A Full Float. I Ordered That Speedy Sleeve This Morning. Ill Know By The Weekend If I Works Or Not. Thanks Again For All The info
Black01Tj said:
Do You Know If These Will Work On A D60 To? I Have A Front That Leaks Some too
The seals are at the chunk on a front 60, You'll have to pull shafts and carrier to replace the seals there.
He is correct the only thing that will come out of the front is bearing grease is that what you seeing ?
It Does It When I Add Differential Fluid. Ive Changed It Several Times Due To It Looking Milky From Water Getting In there
You will have to pull the front end apart to fix it like he said those seals are on the inside of the carrier housing
ECGS
ECGS - Dana 60 Front Axle Tube Seals
Additional Images
SKU: AST-D60-TUBE
Seals-it Axle Seals Size 2 for Dana 60 and Tubes 2-1/8" to 2-1/4". Two Required Per Axle
Pricing: $45.00
Qty:
Add to Cart
Add to Wishlist Item Inquiry Tell a Friend
speedi-sleeved my 14 bolt and havent had a problem since. did put just the smallest amount of black rtv on the inside of the sleeve before putting them on the spindles.
