KarlVP
Love that TOYOTA
So which is better?
Which is stronger?
Which should be used in steering applications for the daily driver?
Which is stronger?
Yes, but a heim doesn't have a nifty boot to keep the dirt out and the grease in. I won't believe for a minute that a properly greased TRE shouldn't last through more cycles than a heim full of dirt.briejer said:A TRE is a ball and race....it's basically a single shear heim. The taper is what holds it in.
SeaRubi said:ream and moog baybee - ream and moog.
stompinjab1 said:The heim is stronger, and if its double sheer its way stronger and safer. Due to the heim case being captured and a TRE is just a ball and socket. If it wasn't stronger we would all be runnin TREs for links. The only down fall is, the life of the heim is short due to them not being greasable. If you ran a TRE with no grease it would wear out in a third of the time of a hime if that. But for a DD I would run TREs with a little grease they could last for ever.
IMO
