Cole1
What are the advantages and disadnvantages of the 27 spline longs compared to the 30 spline longs?
One is stronger then the other.
Go 30 spline and dont look back.
Strength being the main one. . . but i am pretty sure with the 27s you can run your stock inners with them where as with the 30s you have 2 replace them. . .
Hi All:
To use the Longfield 30 spline "super set" one also needs to swap-in Bobby's Aisen hub gear upgrade:
http://www.longfieldsuperaxles.com/products/TOYOTA-INNER-HUB-GEARS.html
Regards,
Alan
You don't HAVE to swap the gears Alan, the stockers will work....BUT if you don't buy the gears, and the stock gear breaks, stripping the stub splines---no warranty....
