Mr. leafspring
KUBOTA BUGGY
let that lincoln locker come apart and itll tear up alot more trust me :****: :****: and i always small tac weld the pinion nut
I'm tacking it this time don't worry!Mr. leafspring said:let that lincoln locker come apart and itll tear up alot more trust me :****: :****: and i always small tac weld the pinion nut
SolidElliott said:Crush sleeve or solid spacers on your pinion?
I have seen some videos of that buggy in action, I can't afford to drive like that all the time. And the 42 non stickies will help a little bit, and the 6.0 is stock, and probably stay that way for a while until I can build a 14 frontBUG-E J said:Well let's just say I have ran into my old toyota problem. I have found a way to keep the gears in tact but I have blown my housing out 2 times now. I'm really rough on **** though. If you don't try to break it you should be fine.
Honestly the heat treating and cryo rcv does seems to be the best upgrade I did. I was more impressed with that for the money spent than the 76 kit.Dirt700 said:I have seen some videos of that buggy in action, I can't afford to drive like that all the time. And the 42 non stickies will help a little bit, and the 6.0 is stock, and probably stay that way for a while until I can build a 14 front
I got something in the making. :****:94xjsport94 said:RJ housing time.
Mr. leafspring said:WELL IVE RODE AS MUCH AS I COULD THE PAST 5 YRS AND CRACKED ONE SET WHEN THE WELDED SPIDERS BROKE AND THE BROKE r&P AT STONEY IN MARCH WELL PRETTY HARDCORE WEEKEND .... TOOK SOME ADVICE AND SET IT Up LITTLE TIGHTER CAME IN SECOND IN THE LITTLE RACE AT MORRIS MOUNTIAN WHEELED IT PRETTY HARD REST OF DAY WITH NO PROBS SO MODERATE RIDING TO MEDIUM HP BOUNCING U SHOULD B FINE :****: :****: but as ol wise tale states .....{ there is no substitute for cubic inches }
I close my eyes so I'm screwednatedawgxj said:OH Yes there is.... DRIVER SKILL!!!!
