LS oilpans what are y'all running?
screamn56 said:
No to derail but what are u guys using for dipstick's
Good question!! I would like to know as well. My super-awesome homemade headers will not allow for a conventional factory dipstick setup.
Kevko, and it has worked great for 4+ years. I bought it knowing I'd likely have to straighten the flange by the ports so it would seal properly, it literally took less than 2 minutes.
RustyC said:
Yes. Front sump also the filter location is center of the pan, not out at the edge. Helps me clear the rear driveshaft. I'm going to try one in a rear engine buggy.
That may end up being the best burrito cooker on a trail machine ever, just need a couple of rubber expandable freeze plugs!
I talked to Rocky at Wide Open Design the other day, an he said in my MAST pan to run a factory dip stick. Fill the motor with the recommended 6qts, crank it, let warm up. Shut off engine let cool an drain back to the pan, an mark it. That's what he said. thumb.gif
