mild XJ Build 92 Cherokee
OK heres what Ive done so far
installed 3" lift
installed 32" mud tires
lincoln locked the rear diff
trimmed the fenders
replaced bad fuses so the heater and taillights work
cleaned out the insides and removed vacant mouse nest from the glove box
removed the rear carpet
total investment
92 stock Jeep that a tree had fallen onto and them sat for a few years $700
tabs and new plates $100
lift from a rolled jeep I had got for $200
Tires 32x11.5 -15 mud kings off a truck I used to own $??
Rims off a ford ranger I used to own$??
things to do
install CB
make up some bumpers
install 8k Warn winch
take it to Walker Valley this weekend and beat it !
future
setup the 8.8 4.10 explorer rearend with a locker
set up the parts jeep front dana30 with alocker and 4.10s I have
Install both
look into SYE and maybe install,
get more flex
rollcage exo type
new set of tires
on borad air
flux capaciter
maybe modify the rear body
Went to walker had a blast! love the setup,1st Jeep Ive wheeled, used to the subaru I like the automatic , it made it past the big rock at the top of rons run , that was my goal as thats were my subaru let me down
need to get a front bumper and winch set up and some cup holders
ready to go again maybe this fri or sat
been thinkin about the rear driveline and how it may slip out the tranny thinkin I could make a arm that hooks to the rearend and goes uo to the frame so it couldnt slip back, something like a tractionbar you see on cars to stop wheelhop but make the front limited so it wont allow the yoke to slip out , here one I found om the net, what have you guys done?
Seems like a lot of work. If it were me I would check it all dump bump on each side and see where it is, I know some companies make a long travel yoke for the Cherokees. Other than that I think it may be time for some money saving and a sye kit and new rear dl.
ok you jeep experts what axles would be a good upgrade for the front, maybe a dana44 but what model and year?
Cheapest would be a waggy 44.... out of an 80's wagoneer. They vary on makes, models. blah blah. Or a cut down big axle 44.....
It takes some money to do this swap though... cant just weld some perches on there and bolt the biotch up...got these darn fangled coil thingies.....:D
so they have a driversside diff?
Nice,Can't wait to do some REAL wheelin with you.It's a whole different world :)
cheers
oh yah!, this rig crawled right over the rock that killed my subaru, I broke both rear axles and put a hole in the oil pan at that spot, the big rock at the top of rons run
workin on bumpers
got this rear one on needs some corner protection, made up a 2x2 recovery point
figurin the front out, want good protection for the lights and rad and a winch mount
Gotah love the ole home made cherokee bumper project. I'm in the same boat I have yet to do my rear bumper either... due time I suppose. More steel lots welding and a big hammer= a good time!
