civicmindedex79
BUG-E J said:There is a 3500 dodge on here for sail that needs an engine. Price the job and see if its worth buying. I suggest looking into seat covers and an air freshner if you go that direction
1tfrot said:not sure what grade that section is, but vail, Eisenhower area in CO are 6-7% grades. those are big boy pulls and the newer diesels have no issues with those. my previous d-max had a tow tune that was about 100 over stock and my previous setup weighed about 15,000#. with the tow rig I was 23K. let'r eat in 4th gear and never had issues on those grades.
honestly, you just need more truck. imo, plan B would be the best option if you're happy with your current truck as a DD. if not, then plan C.
and definitely trailer brakes
my current setup is a 2016 d-max (stock) and a 24' enclosed. total is about 17K loaded for a trip.
poolman said:That's gotta be Kel!!!! :****:
I'm pretty sure mine has 3.42's in it bc it pisses me off pulling a 12' single axle lawn mower trailer, especially with those bigger tires on it. Sure do miss them 4.10's in my old 3/4 ton gasser.TBItoy said:220 and 220 ain€™t overheated.
Light up that little wagon and let er eat.
Big grades like that will slow down and add heat to pretty much anything short of a hot rod older diesel or newer diesel.
I pulled a 1500lb boat with my 1500 (5.3 with 3.42 gears) and I wanted to pull my hair out. It felt weaker than my old Duramax with a 34€™ trailer, 2 rigs, 3 passengers, and a weeks worth of camping gear... of course it has 1/3 the torque.
TacomaJD said:I'm pretty sure mine has 3.42's in it bc it pisses me off pulling a 12' single axle lawn mower trailer, especially with those bigger tires on it. Sure do miss them 4.10's in my old 3/4 ton gasser.
Luke, if you can deal with the fuel mileage bringing the suck, the 3/4 ton gm gassers will be a significant improvement over what you have and nowhere near as expensive as a diesel. My trailer wasnt as heavy as yours, it was an 18' all steel dovetail dual 3500 lb axle bumper pull trailer and my full bodied rig with full cage wasn't exactly light weight. I always figured the trailer and rig weighing total somewhere around 7-7500 lbs or so.
My old Chevy 1/2 ton had 3.42s and it pulled like a champ. Wife's Tahoe has 3.73s and I'm not sure if it's the difference between the 5.3HO that my truck had and her standard 5.3 but I swear my old truck pulled a lot better than her Tahoe. I know that may not make sense but I almost wonder if at highway speeds that the 3.42s put my old truck right in its sweet spot at 70 mph and it seems the seet spot for her truck is to just stick it at 65. I also try to consider that maybe the big block is just spoiling me.TacomaJD said:I'm pretty sure mine has 3.42's in it bc it pisses me off pulling a 12' single axle lawn mower trailer, especially with those bigger tires on it. Sure do miss them 4.10's in my old 3/4 ton gasser.
Your 7.3 gets the mileage of a Prius! Go pick it up it's only time! :flipoff:Zjman said:if you were only closer I€™d be all over that
onepieceatatime said:My old Chevy 1/2 ton had 3.42s and it pulled like a champ. Wife's Tahoe has 3.73s and I'm not sure if it's the difference between the 5.3HO that my truck had and her standard 5.3 but I swear my old truck pulled a lot better than her Tahoe. I know that may not make sense but I almost wonder if at highway speeds that the 3.42s put my old truck right in its sweet spot at 70 mph and it seems the seet spot for her truck is to just stick it at 65. I also try to consider that maybe the big block is just spoiling me.
blacksheep10 said:I've had 3 6.0 gassers. All 4.10/auto/ran well. The one that had 33's and aftermarket wheels sucked pulling my gooseneck with. More downshifts on hills, wore milage, worse stopping. It makes a difference that can be felt by something with limited power IMO
