My Angryfab buggy "ISSUES"
do you by chance remember what size thread you tapped the two water pump ports? npt? awesome build, those angry fab chassis are it!!
What Enzo said 3/8 npt and 1/2 npt. You don't even need to drill them
Re: Re: My Angryfab buggy "ISSUES"
Thanks
Few pics, getting closer
kmcminn said:
White looks good!
Hey :dunno: I thought you weren't doing white cause everyone in Arkansas has white?
Thanks
I was going to to gray and green but durwood durens is that color. So I went back to White
nealcj8 said:
Lookin Pretty sweet!!!!!
Thanks, hopefully couple more weeks and it will be done
Dirt700 said:
Tapped the trans pan and water pump.
Bebop said:
1/2" and 3/8" are the std for LS water pumps.
https://www.pirate4x4.com/tech/billavista/Cooling/
I read somewhere on Pirate the other day a guy complaining about a cooling issue after tapping. Any experience with that?
chris demartini;44043576 said:
Another thing if you're keeping the thermostat, loop the heater hoses. I blocked the ports and had trouble with the thermostat not opening so I deleted it and used a restrictor instead. Keeping the heater fittings and looping them would have solved that issue as well.
I know brad Evans has his done that way, and I don't think he is having any problems. Mine isn't running yet, so I can't say for me
Thanks
onetoncrawler said:
White and green look awesome together
I think Waffle on here also complained about the system being hard to bleed with this modification.
I think Gates has a small hose to connect the 2 ports and not have to tap them.
Edit : read this : https://www.facebook.com/notes/agearhead4life/dont-plug-the-heater-ports-on-a-lsx-water-pump-heres-why/704643956255902/
All I know is that Lori's buggy is set up with the ports tapped shut and my Vortec is too. Both didn't have issues. So far so good.
