Got the fronts on the two drawers... Turned out pretty decent... Later on I may find some small aluminum angle to wrap the fronts with... Gonna try and get the upper cabinets skinned today, then all they will need is paint and installed...
Not exactly foam panels but I can get ALLOT of free floating dock foam.
How thick is it??? Wonder if I could cut it without ****ing it up and making to much of a mess???
OK, I found a black tank that fits perfect under the bus... I need to relocate the inlet for the shitter on the tank though... Any ideas???
Thought about cutting the inlet out from the tank and using rtv and some screws to refasten it... Then seal up the old hole...
if it is a fiberglass tank, i would just use some fiberglass cloth and resin...
if you need some cloth... i think i might still have some laying around that you can have... don't have any resin though...
I think Schucks carries resin in small containers, youll need some catalyst (hardener) as well. If only I still worked at my previous job I could have hooked you up with everything you would need
I think the stuff is called tacky tape.
http://www.rvwholesalers.com/catalog/tacky-tape-13-0865.html
Send me a PM, I probably can get you some for free if you want it.
Nice work by the way.
