My comp rig REVAMP
I decided to go ahead and re-configure the battery packs on more time--ended up moving the 2 cells that were on the servo to the sides--triangle shape.... I also went and swapped everything over to deans plugs. Not 100% sure how the velcro will work out but I will run it and see what hapens...
And of course--- With a new rig I needed a new body----ok I just stripped my old body(which I like) and repainted it with the same colors as my bronco body was--I like it MUCH better than the blue....
looks really kool. how do you like those rc4wd tires i heard they were kinda stiff. they look ****in neat though:awesomework:
Well I had planned on this upgrade but the timing was perfect as my ESC dropped dead..
But its the novak goat brushless setup--this should hopefully do the trick
Ok the rig has been doing pretty good and holding up for the most part(blows drive shafts alot). But since its time to build a 3rd rig for my lil girl--I figured I would upgrade/chance my rig and save the old parts for hers....
Starting with this-----ax10 tranny and dna dig....
Nice Crash, good upgrade. My R2D trans/dig set up needs to go as well. I'm thinking of putting it on the scaler since I wont be running dig on it and going to the ax10 as well.
granted, I haven't touched either of the crawlers since we moved into the new house. :rolleyes: They'll make good winter projects to get them going again.
Make sure you upgrade to metal gears in the tranny. I have blown two sets of the plastics and it sucks setting up the VF dig everytime as it is picky about tolerances...at least mine is
slacker :redneck:
The R2 will be going in the new rig for my lil girl :awesomework:
For now I am going to run the tranny as is (drive gear is metal) untill I figure out if I am going to do another chassis or not....
Are you going to keep running the Goat with the AX-10 tranny?
I've got some video of Marcus's ax-10 crawler with a Goat. RIDICULOUS!!! :redneck: The wheel speed is nuts. That the route I plan to go.
