My toy
They're ARP's, they do make nice stuff...
Truck looks good---i saw those 37's on CL, looks like new!
Yea, just the hex on the end of the studs is sweet!
Those 37s were perfect timing I was just starting to shop for tires and was torn between the 36"iroks and 37" MTR Kevlar. Didn't want to go to a 17" wheel and didn't really want bias tires. These 5 mounted/balance were about the same as 4 bias iroks.
The spare still has the sticker on it. The other 4 are like new.
I either bent my front housing and/or crushed my knuckle ball. My brass bushings in the spindles are all egged out and I can't get my driver side birf out. Soo now I have plans the week of Christmas that I'm off work.
Move my axle forward, build a new front bumper, weld up my air tank, build a spare tire carrier, maybe finish my exo and get my rock assault and dirty 30s under the truck.
These just showed up today.
I'm going to try to get my axles and 3rd member out tomorrow. Selling my 3rd member and buying a high pinion. This is getting more expensive by the day!
The Toyota is up on the lift going to get started swapping housing's in the morning.
Since I'm running on the back hole on the perch to move my axle an inch I made some extra support for the springs.
Full droop... before the high pinion my driveline bound up at full droop with my case clocked 10deg.
You mean caster set at 10 degrees? Only way to accurately measure caster clocking is with the weight of the rig on the axle/spring assembly...10 seems quite steep...
That was suppose to say T case clocked at 10 degrees. (Stupid smart phone auto correct)
0 Words
