Need a stronger Toyota trans
AW10 said:
I'm using this plate to mount to my frame. Is the chain driven case the same 7 hole pattern? http://www.lowrangeoffroad.com/toyota-off-road-parts/79-95-4runner-hilux-pickup/transfer-case/diy-toyota-transfer-case-crossmember-center-plate.html
I bought a marlin short throw shifter for the g52. Is has the same part number as the r151f but not the same part number on the r150. Not a deal breaker but it sucks to not get to use it.
I gotcha now.
No the chain case is not the same (it doesn't even have bolt on tail housing).
yeah if you can get ahold of an R151 and tcase, that seems like the way to go for you. (the tcase is 23 spline on the r151, so yours wouldn't just bolt up)
