ain'tstuckjustresting
RIP Mister 12/5/12
Also make sure you have a full charge on the battery.....Low voltage can make it do strange things....
13.8v @ the ECU check using the all 3 ecu ground pins also.
Which should have closed the IAC but you say it didn't. This leads me to think something is wrong with the system as it relates to the IAC......I did the procedure as stated, jumping the aldl, key on, unplug IAC, key off, remove jumper, start engine.
At this point you should be able to close that vacuum leak and the IAC will open correct?So this is what I tried: I created a metered vacuum leak (Booster line and clamp) and closed it down to achive the lowest smooth idle w/o surging (about 900rpms). I put my finger over the IAC port and can't feel any vaccum so the pintle must have closed.:
Yes this is what I would expect but that doesn't mean it's working exactly like it should.......I would hate to send you on a wildgoose chase here and it's hard to say over the net exactly what is going on. It SEEMS as though the IAC isn't working quite right by what you've said. Why that is is hard to say...I open the throttle a bit and can feel the IAC start to pull vacuum on my finger. It must be reacting to the TPS command and allowing more air in to increase rpm. If I continue to block the IAC port with my finger and open the throttle more it will pull even harder through the IAC port. In a correctly operating system this is what you would expect right?
I bought the harness and eprom from Howell EFI. I got a copy of the pinouts and haven't found any discrepancies yet. Not serious supply voltage issues like you had either. My TPS is dead nutz .6v at throttle closed as per spec, so I don't see why that would need to be adjusted to .54 as listed in the link from Binder.
They guy at Howell was a douche when I called him, pretty much no help. He said they test all the harnesses and chips before they leave so there must be a problem with the engine or ecu.
Company i bought mine from said the same thing.
I'm pretty sure all the TBI info in the link is for the older ecu with the black plugs mine has the red and blue plugs. I'm not sure that info will work on a Vortec.
i have the correct pin out and they are different.
I just had the plenum off last night to double check everything. It was oily in there from the very rich exh being pumped in by the egr but there was no fuel pooling around the lines or regulator. I cycled the pump a few times to make sure there were no leaks.
I made a block of plate for the egr just to eliminate a stuck pintle. I'll remove it once I get it running decent.
I'm pretty much at a loss here.![]()
Hip, did you have to use the DRAC or VSS? When I bought the harness they said none of that was needed for the engine to run, but when I talked to the douche at howell Friday he said he thought the DRAC needed to be hooked up.
Well the way I'm reading things it should run decent with everything unplugged but the MAP, TPS, ECT, and IAC. During open loop those are the only 3 sensors the ecu needs. Well I checked the input signals on all 3 at the 32pin connectors and they are in the standard range for warm idle. It still runs pig fat though. Everything points to a internal fuel leak but there are 0 leaks, all new parts and it holds 60psi for a long time key off.
What's the O2 signal reading...Even in open loop?
I'm gona guess zero if it's unplugged.:flipoff:
Aint stuck.....What modification have been done to the engine?
I can post the whole session but you need Datamaster open it. (it's free):awesomework:
How do you open these files? (I can't seem to be able to...:booo![]()
