need some pointer's ?????
u said u had the battery tested. but how? was it load tested?
it can show 12v, and STILL be bad.
Did you happen to clean the terminals? or just tighten them? Clean them fawkers up real good with either a terminal cleaner or a small wire brush. Do the same at the distribution block and the starter. THEN tighten everything down.
From the sounds of it, you're bypassing the battery when you jump it by clamping to the cables, but it's never getting a good connection to the battery, not allowing it to charge.
well i had the alt,batt,and the starter tested and they all tested good.
so i put it all back together and then i checked the grownd cable that run's to the block an low an behold it was loose!
but i remberd that i undid it last night trying to get the a/c
pump bracket off but the thing was already loose when i tryed to take it off last night so i think that was it from jump street.
anyhow thank's alot guy's for your imput.
no that's the funny thing i did!
hell all i know is i got it to start then i shut it off an did that a few time's to make sure.
but now im gonna go back out there and try it again.
0 Words
