Newbies Post Up Here - Rig Specs & Info Thread
  • Start date Start date
Not much more than your average Samurai.
Linked front and back
King Air shocks at all four corners.
Hydraulic assist.
KORE DIY beadlocks
36 inch Super Swampers
Rock Block
6:5:1 t-case gears
Toyota Axles
4.11's locked front and rear
Propane
Antirock sway bars in the rear
-H
I guess I'm a newbie here too... Def not new to wheelin or buildin but new to hardline... Thanks to race10 and twistedzuki I found y'all..... First pretty capable ride I had was an Exo'd yota on 38s linked rear full hydro and more bs... 2nd was a tube chassis yota buggy on 39.5 tsl's... Buggy worked really well but taught me a lot... I like my cab trucks... Currently starting a tube chassis 2000 s10 ex cab...If y'all r interested I'll do a build thread... I'm from Cincy, and love Harlan but I'm very interested in comin down to wheel with the southern boys! Enough bs talk here is a few pics of my old Rides
i built this 99% by my self with a 110 welder torch and sidegrinder its my first real build
carbed 4.3 with 650 holley
700r4 208 transfercase
hybrid front drive shaft i cut the toyota and chevy drive shaft and welded them together
stock rear chevy ds i shorted and welded the new yoke on
custom motor mounts and trans crossmember(they were a bitch)
running the stock ac condensor and fan as the tranny cooler under the rear seat
lt headers i beat the hell out of to fit between the frame rails
i had to get the new radiatior i bought modified with a 90 to miss the altenator
i had a buddy cut me some shackels and spring mounts with his plasma cutter,i had to weld on a new shackel mount for the fronts.
installed jeep yj springs,had to reweld the rear spring perches on a 26 deg and so the ds would work
welded the spiders upon my toyota axels and installed them
bolted on a high steer kit,drilled and plated the frame and mounted a toyota ifs power steering box.
put in all new gauges mounted them in stock ac vents,modifyed the t/case shifter to work in the samura(pita)
mounted my holley red pump and ran all new lines,wired up the motor and fired it up.
it hasnt ran in three years im pretty anxious to get it out and flip it off a hill.
Back wheelin with a new ride. Nice to fart around in w/ heat and ac.
Newborn from western nc. Im on nc4x4 but heard bout this and figured id join.
79 ford bronco "Moby ****"
-460efi
-np435 4spd with np 205 case
-D44hd 4.10s detroit
-sterling 10.25 welded 4.10s
-6in lift
-38.5 cut boggers
My name's Reuben, I met a couple of y'all at the toys for tots run at Grayrock this past weekend... I broke a passenger inner axle HP 60 shaft in the AM and then broke the driver side on the same trail in the afternoon. Had a blast on the 5 trails that I did get to do though. Going to try to get with Keith and get some people together for another run there sometime soon.
I've mainly been trolling on the forum for the past couple of months, figured I'd post up in here.
I've been out of wheeling for just over a year and just now getting back into it.
I bought the orange 321 buggy that was for sale on here a couple of months ago. I've done a few minor "fixes" to it already and have in mind a couple of things I want to change. Already thinking about changing the chassis out also
383 stroker fuel injected
hooker headers
7 quart oil pan
PTC built th400 w/10"nitrous torque converter
Grifflin aluminum radiator
flex-a-lite dual fans
Fox 2.5 coilovers
Fox 2.5 air bumps
corbeau baja ultra seats
Warn 9500HS
wilwood dual master cylinder disk all four.
15 gallon Aluminum fuel cell
PSC steering (double ended ram, PSC pump, PSC cooler)
Ford HP 60 4.56 geared and detroit locked
14 Bolt 4.56 geared and detroit locked
GM 203 doubled to a 205 Ford
42" TSLs on 36 bolt beadlocks
This is the first rig I've bought... I've built all my past rigs.
Old Rigs:
The rig I sold about a year ago
JK on 37s, RCVs, hydraulic steering assist, front and rear winches, with tons of other **** on it... don't really feel like listing it out
1983 CJ-7
Dana 60, 14bolt, and 1link front and rear on airbags... tons of other **** on it as well...
ATX780 said:
1983 CJ-7
Man I'm jealous of how that CJ turned out. The one link with air bags is certainly some out of the box thinking :woot:
here we are ...
basically what i have is
350 sbc.4l60e/205.......swappin in a sm465 at the moment
tube chassis
s.a.w. 2.5 front 2.0 rear airshocks
5 ton rockwells
46in goodyear military tires
hemmit wheels
3 link front
1 link rear
120 in. wheelbase
27in belly height
and a very slim 7500 lbs....lol
only had it out once so far and broke the tranny housing so we are swappin in a 4 speed...lol...gona throw some gears for a while
its by no means comparable to some of the rigs on here but i hope you like her anyway....lol
http://i266.photobucket.com/albums/ii267/37volkswagon/47da1882.jpg
http://i266.photobucket.com/albums/ii267/37volkswagon/4579518f.jpg
http://i266.photobucket.com/albums/ii267/37volkswagon/6b733a10.jpg
as it sits now
turned onto this site by a buddy, i like it!!
70 something cj7
86 frame
93 yj tub
cpi 4.3, th350,203, flipped 300
89.5 ford 60 front 4.88 elocker
72? ford 60 rear same
h1s 39.5 irocs
hydro assist
sprung over front sprung under rear
everything pretty standard and reliable
Hi, my name is Clyde. I met a few guys from here at the HPO hill climb yesterday. I've been wheeling all over the south for about 20 years now in all kinds of rigs or four wheelers. I usually don't stop wheeling long enough to take pics but I got a few of my current rides.
From Baja last month.
A few 1:10 scale.
theglassman said:
here we are ...
tube chassis
5 ton rockwells
hemmit wheels
3 link front
1 link rear
120 in. wheelbase
27in belly height
as it sits now. Need more info on this beast
87 yj
1999 buick 3800 n/a
700R4
231/300 doubler ( flipped )
hp 60 front ( 5:13 ) arb and 4340 shafts
d70 rear ( 5:13 ) detroit and 4340 shafts
four link front / rear, 16" radflo 2.5 air shocks
shitty poser yard shot!
hey guys, new to the site, lurked for a while, been fabbin, wheeling and welding for years. i have a my current ranger build over on pirate, basically a 90 ranger, 76/10.5 sterling, blown 302, e4od, bobbed alot, exo, atlas, 42 rockers, c/overs, etc.. almost done with it, really enjoy this site so i joined up. i cant figure out how to post pics from my computer, heres a linky: http://www.pirate4x4.com/forum/showthread.php?t=849133&highlight=super+ranger
Hey guys lurked here for a while now so i thought i would say hey and post my stats on my rig.....however most of your guys RZRs are built better then my rig
1988 samurai
5:12 front and rear locked in the rear
31x10.50 swampers<<<<<yes they still make them that small
Rock 4xFab NCZ cage
ZOR bumper
1.6 8v tracker motor
spoa with rear leafs up front and missing links
not much but its fun for me and the family to get out on the trails with
most of my buddys have buggies and some day i will have mine!!!!
little over three years and i wont have to worry about a kid in the back seat and the sammy will be turned into my dream machine
OK A little bit about me ....35 years old and i have been working at a prison for the past 14 years...most of it spent in the "HOLE"
as a seg. offer ........ married with 2 boys that love to hunt and fish and here are a couple pics of my sammy
1979 Toyota Pickup Long bed
99 2RZ
W56
MC Dual comp clutch, 30 lb Fly
Dual Case
High Steer w/ 5th stud and Trunion Elim.
Dual cases, Marlin Adapter
RAD Designs triple stick
5.29 Gears
Taco rear axle w/ e-cock
Taco width front end lockright
Bobbed Bed 13"
Davez tube doors
Civic seats
Optima yellow top batteries
Raceline Bead locks 36/12.50/15 TSL
Roundeye Headlights 6000k HID
in Russellville, Ark. just recently found this site and like others, been lurkin a bit , so pretty much a newb here.. had alot of rigs in the past, jeeps,cruisers,mini,sammi, and early broncos.. currently wheelin a
04 rubi, on 79 ford d60's 35 spline chromo throughout with long front joints, 5.13's, detroit rear, grizzley front, nv3550, atlas 5.0 ,4 link rear ,106"wb, radius arm front, 17" TR HD's with 42" irocks , corbeau baja seats.. warn 8274 etc...etc...currently savin for coilovers, its kinda street legal ;D or at least its licensed...
and a 85 fj60 cruiser, OME lift, arb bullbar,8274-50, 33" km2's, 4.11's we use this as a weekend get away rig...
