Newbies Post Up Here - Rig Specs & Info Thread
  • Start date Start date
Hey, name's Jim. Seen a few of you at MM. Currently running a stockish TJ, but building a truggy out of a 76 F-150. 390/c6/205.
My name is Chris Beyer and I currently live in Broken Arrow, OK (near Tulsa). I was from Great Bend, Kansas before I moved to Oklahoma.
I have a K.O.R.E. Rogue Quattro 4-seater. Love to go to Clayton and Hot Springs.
Video -
Pics -
i guess since i work to fast for a build thread i'll just cram these in here... :flipoff1: anyways i am ready to REALLY beat on this motha sucka now.... see yall next weekend...
here it is as it sits to go to golden mtn in two days... the shock pic is how i retrofitted airshocks to the rear of the chassis...
name is steven from mounds ok . here is the buggy i built this winter. here is the specs.
350 CHEVY ENGINE FUEL INJECTED
TURBO 400 TRANSMISSION
DANA 300 TRANSFER CASE ROTATED W/ CABLE TWIN STICKS, 4:1 KIT & BIGGER OUTPUT SHAFT
FRONT DANA 60 W/5.13 GEARS, DISC BRAKE CONVERSION FOR 15" WHEELS, SHAVED DIFF & DETROIT LOCKER
REAR 14 BOLT STEER AXLE WITH 60 OUTER KNUCKLES AND CUSTOM SHAFTS AND CTM U-JOINTS W/5.13 GEARS, DETROIT LOCKER, CUSTOM DISC BRAKES, SHAVED DIFF
16" FOXS SHOX 4 LINK Y BAR UP FRONT
14" FOX SHOX, 4 LINK DOUBLE Y BAR IN THE REAR
44'' TSL ON CUSTOM BEADLOCKS
ON-BOARD WELDER
ON-BOARD AIR
Here's my mall crawler 97 TJ R.E. 5.5" long arm kit, Super35 kit in the rear, D30 w/chromos and a ARB both W/ 4.88s and a soon to be added Warn 8274.
90 toy 3.0, full chromoly dana 44 with lockrite in the front, 12 bolt rear, 5.38 gears tube bed,36'' irocks
[attachment deleted by admin]
89 YJ
60 ft-leaf springs
70 rr-3 point coils
with 6.17's
44 TSL's
5 to 1 Atlas
4 extremely angry squirrels pushing everything
mostly wheeled at Clayton
but been from superlift to Moab
and a lot of points in between
Donnie
well i figured i needed to introduce myself since i have been lurking on here.
names david hall,
specs are
90 xj
6" bastard lift
custom high steer
on board air
warn winch
tnt flat belly skid to protect the goods
d30 upgraded shafts 456s with lockrite
d44 outa a tj 456s detroit
High output motor auto tranny and tcase with sye
35" claws on steelies
full 6pt D.O.M cage
cut up body
in the process of fabing a front bumper and long arm
well here she is as of now (shes always changing) some pics are blury cause i suck at taking pictures :flipgotcha:)
here she is when i first got home
FNG P.H. Vickery here... 21 yrs old, senior at SHSU ...i've got possibly the cheapest/ smallest rig on the board, but she gives hell... RIG: '93 Cherokee 6cyl 5spd, 4" lift 33" TSL 8.8 rear/ D30 front cheap winch and a hard head driver.
Started out with a LJ on 36's & alloyed / locked 44's.
After tearing it up in Clayton the wife took it back from me  ::)
Bought a POS YJ on Sunray 9's w/ Atlas, Added lots of $$$$
Got tired of breaking crap so I parted it out and pick this up over the weekend
Specs:
Ford 5.0L/C6
Atlas 4.3
35 spline spider 9's, flipped, spooled
Krawlers on WE's
110" WB, 19" belly and really cramped inside  ;D
Hopefully will have a little better luck with this one....
Matt O, John G - when you guys coming back to tackle middle slims?  I am ready now!...I know you want another shot at it with your new rig Matt!
Hello all,
Began lurking here after Nolen cross posted where Caddy on Dubs went...and this is certainly not a bad group.
For sale --->
Both also for sale ---> '07 Power Wagon fully loaded black on black with dubs for pimpin and Dodge 3500 4x4 Cummins for towin.
07 Gary Fisher HiFi Deluxe for trails
07 Redline COnquest Pro for road/commuting/cyclocross
Built a rockcrawling course on our land in TX:
Well, here's my story. My name is Gregg and my junk is a blue with yellow flames T-1 chasis I bought from Tanner Off Road in Colorado, or at least that's where it started life at. This was there shop Rock Racer until I got ahold of it and trnsformed it into what it is today. Since then I (with a lot of help from Keith @ ORC and Daryl @ Custom Tint and Auto and MANY others, thanks) have rebuilt pretty much everything from the tubing, paint, engine, suspension, interior, wiring, and much more. The motor is a warmed over 355 small block with a Howell TBI, followed by a rev. ma. valve bodied TH350 with a 2600. It all goes through an Atlas 4:3:1 and ends up at a pair of Rockcrusher 60's with 5:13's and a detroit and ARB. 44" Tsl's are the rags of choice, but swap in a set of 40" pro Comp's on 20" Gowdy beadlocks for the bling blang. The rig has transformed from an air shocked and air bagged suspension to a coil overed, stretched to 111" wheel based buggy. It also has some pretty good tunes so I don't have to listen to myself all day. I live in Chelsea Alabama and frequent Grayrock, Morris mountain, and anywhere else I can get to. Thanks again to all the people that have helped me in this build. thumb.gif
newb here from nc. my trail rig is a 74 bronco /302 on propane/performance automatic c4/ and dana 20 toothpick waiting to snap. currently 108.5" wheel base ,one tons,5.38 locked,42's,stazworks wheels,exo cage.
right now im pulling out the one tons and going with 112" wheelbase,47's, beadlocks,psc fullhydro,4 link on both ends,rockwell axles.
Hello Tom From Oregon here. I came across your site looking for 14 bolt shave pics. I have a buggy I have been working on for about a year,Specs are Chev 350/400/203 ,14 bolt /10 bolt,37"toyos 17" beadlocks ,full hydro, coils /leaves,112'WB. Its getting close to running ......any day now....
Rusty told me about the site so i thought I'd check in.
This that and this and a........
THANKS FOR THE PIC NOLEN
Thomas from North AL- Rigless right now. Sold my 1-ton runnin'YJ last year
Now daily drivin' an '06 TJ
Doing more passenger seat wheelin' than anything. Rode KOTH w/ JAB and let the record show that I was still at the house icing down the cooler while the drivers meeting was going on. As far as the cones went, I KNOW NOTHING. Good times...............
evening every one,
i was brought over here by Brain (1TONZR2)
its a 92 Suburban, TIRED (250,000 miles) stock 350TBI & 700R4 (currently busted) D60 Front/14B Rear, 5.38 Gears, Detroits, 44 boggers on TR BL.
here are a few pics of my "RV"
thats big bitch...
little info
1 tons, 5.38s, full hydro, 4 link front, 2.5" Fox coilovers, long leafs out back, used to have 47 LTBs, now running 44 puddin pushers, big fawkin winch, lots of body damage.....
used to be nice!
Tony here from Nashville.
here's my ride. mostly built myself, with some help from the boyz at EOR now and then. jimmy and his crew are the bombdiggity.
seen a few of the hardline guys around, rode with a few over the last year.
its what's left of a 89YJ. TBI 5.7/built TH350/4to1 Dana 300 (soon to be atlas 4.3)
chevy 60/lincoln locked and alloy shafts
14bolt shaved to 13 out back, lincoln locked
42's son. iroks that is.
110wb
bilstein coilovers.
9.0RC behind the grille
backhalfed, front halfed, probably middle halfed eventually.
4link rear, wishbone 3 up front.
hydro steerin
lotsa tube work, some by me, some by jimmy.
bumpin sound system
Checkin in and sayin hey guys.
Started out with this:
99 4Runner - Lifted and locked with some armor
Hacked together a 1st gen w/ dual cases and a welded rear to beat on severely then got offers on both vehicles that I couldn't refuse.
My new daily driver and part time track car
Now building a new 1st gen to get back on the trails
From when I picked it up last month
Swapped in Rears up front, Longfields, Welded 4.30 thirds, and Crossover Steering so far. Going to be adding a flat belly, dual cases, 4.7's, Grooved 38" TSL's here shortly along with some toob.
