Newbies Post Up Here - Rig Specs & Info Thread
  • Start date Start date
99 Jeep Grand Cherokee Limited (LOADED w/ factory options)
WHITE FACED Instrument cluster (Factory 2001)
4.7l modified w/ moderate cam and heads
K&N FIPK
PIAA Superwhite lights w/correct harness
Infinity Kappa Perfect speaker system with Infinity Kappa amp
Duel Optima red Top Batteries
Painless duel battery system mounted in cabin
Cobra NW40 CB
Bold Design front Bumper w/ D Rings and cutouts for 5" lights
Bold Design rear bumper w/ D rings
Bold Design fuel cell (were the spare goes) 30 gal
Warn HS9500I winch and a Ramsey 15000lb
Custom made Rock Rails
Clayton's Longarms
Custom lift (Springs by Valley Spring Works)
Billstein NEW 7100 shocks
JKS Adjustable track bar
Custom made drag link
Now for the goodies:
Front axle:
High Pinion Dana 60
1.25" wider than stock w allied beadlock wheels with 1.25" more backspacing to give it a 2.5" wider stance per side!
Mosher shafts
Warn Premium Locking hubs
4:88 gears
ARB Air Locker
Disc Brakes
Rear Axle:
High Pinion Dana 60
Mosher shafts
4:88 gears
ARB Air locker
Disc Brakes
Transfercase:
231 Cherokee T/C with a Tom Woods short shaft kit, tera 4:1 tera low kit. Converted to use the STOCK T/C Shifter in cabin.
Driveshafts:
Tom Woods front and rear custom made driveshafts. These are stout and use CTM U-Joints on both.
Allied Beadlock wheels with 36 locks. Black powdercoated
38.5X15X15R BOGGERS
Im Justin Maloney , from southern ILL .
My Rig . 99 TJ Body
350 engine
350 trans
4.3 atlas
Edelbrock Pro-Flow 1000 fuel injection
PSC Full Hydro , Double ended ram
Rear Ford dana 60 High pinion 4.88 Rev.
35 spline Detroit
35 spline Moser axles
Front Spider Trax 1550
spider trax 35 spline inner /outer axles
300M U- Joints
detroit 35 spline high 9 center 4.88 rev.
drive slugs ...
double trianglated front and rear suspention
6'' lift coil springs
willwood 4 piston calipers
twin Howe manual master cylinder
39.5 - 18 - 15 Boggers
15/10 3 inch back set 32 bolts bead locks .
wheel base 103''
Theres probley somthing i left out .. ????
This is an older pic . Not show is the new cage and paint job..
BMan from Marietta GA
97 Jeep Cherokee
- 3.5" RE SuperFlex lift
- 35" BFG MTs
- ZJ Steering
- Custom sliders
- Custom bumpers
- Custom round headlights using Zuk brackets/lights.
- Custom rear bump stops
- Extended front bump stops
- Modified fender wells and reworked foot wells.
- Currently Dana 30 lock right locker/Chrysler 8.25 rear (Going to weld it up since it will be a while until I put 14 bolt in)
(14 bolt sitting on workbench w/detroit locker, Cadillac Eldorado calipers. I have a HD HP Ford Dana 44 housing but will probably go with Dana 60 instead.)
- Custom Long Arms 2" .250 DOM
- Custom XMember similar to Clayton's
- NP231 SYE
- Using front Cherokee CV drive shafts for front and rear.
- H2O UJoints in drive shafts.
- Yellow Top Batt
- Cheap Champion 8K winch with Viking synthetic line.
- Brown Dog Motor Mounts
- Magnaflow Hi Flow Cat
- Flowmaster Super 44 Offroad version
- Cobra remote CB
- Alpine head unit
- Phoenix Gold amp
- JL Audio 10 sub
- Polk Audio front separates
- Infinity rear in overhead soundbar
New guy here! I don't post much........just lurk in the shadows and enjoy reading everyone else's posts! ;D
The Rig:
Jeep TJ
Mustang 5.0, AODE, Atlas
Dana 60's, 44 TSL's
my name is TYLER REEVES
some of you no me some of you don't
well heres what i drive
cj 7 LT1 with a little tweak.. it my get stroked 1 day but it will leave 2 long wide black marks down the drive way now lol
Atlas II
grooved 44 boggers on beadlocks
locked 14 bolt and 60 with high alloy axles rock crusher drive flanges
all the goodies
4 link front coil overs with air bump stops
4 link rear with leaf springs soon to be air bumps and coils !!
wb 118 5/8 gonna stretch it to 120 when i redo the links
theres really to much stuff to type
[attachment deleted by admin]
just figured i would post a pic of another toy of mine...i got this truck stock when i was 15 and i just turned 24 and i have held on to it and dont plan on it goin anywhere anytime soon...added a few things to it since then ...oh by the way its only a pavement pounder except for a mudhole every once in a while :drinkers: :driving:...WEAK i know but i just hate to beat the body up...well here it is
87 Yota Pick-up
SAS from All-Pro Off Road done by James Vest or "JFAB"
6 inch springs with Bilstein shocks
37 inch Iroks
whut up hardliners, my name is Neal and i have a fetish for 4x4 Toyota's in the Land Cruiser flavor. i wheel a '74 FJ40 that is baby blue, beat to **** and looks like it was fabbed up by retarded monkeys, it does currently work pretty well so i can't complain. Mountainside is my fav park but i also think that Mayhems and Golden mt. are the heat.
p.s. Scott/Julio is my hero
I'm Preston from jacksonville Al. I've just got into crawlin,been on a couple rides at choccolocca orv park.
here's my rides.
03 f150 on rockwells,with rear steer,stock 5.4 triton V8,stock tcase.
87 toyota 4.3 chevy V6,350 trans,203/205 doubler,on rockwells.
Aaron Jeffords southern il
85 cj7 on 80 k5 frame
350 out of a early 70's vette
th350 with np205
10 bolt front 4.56 lincoln locked
12 bolt rear 4.56 locker
holley 670 truck avenger
38x12.50 tsl's on 15x10 steelies
and alot more to come!
thanks guys thumb.gif i went to flat nasty last weekend and figured out the full size frame sucks! thinkn about a drivetrain swap now! any suggestions? thinkin early 80's yota?
Hey whats up? I live in East Texas but the east side style of wheeling is more my thing. Anyway I just sold my Formula Toyota a couple of weeks ago and stopped by EOR and picked up a 321 chassis. Thanks again Jimmy!
Here are the planned specs.
321 Chassis (bought)
PSC steered Rocks front/back (bought)
47" LTB's (bought)
6.0L LQ4 with Jims Performance harness and **** (buying this week)
TH400, RMVB
Atlas (still deciding A-II or 4 speed), considered LoMax 205 also....?
FOA coilovers and airbumps, unless someone talks me out of them.
Thats about it really. Ima hammer down, bangin off the freakin rev limiter type of wheeler. I cant stand that crawlin' stuff. Probably gonna have to call up Randy Oveurson after the first outing and sale a kidney of something.
Hey man thanks! I will post up something when I get it all pulled out of the boxes and get my Rocks and 47's from Beaumont. No need to post up now.....nothing to see here. LOL
Sweet man, how bout some specs on that machine. Looks light and fast. Let us know if you get a chance to play in Bama. thumb.gif
well i've been on here for a little while but jus now saw this thread lol.
i've got an
88 suzuki 107.5 in wheelbase
1.6 on propane
dana 44 front and rear
4linked w/ airshocks in the rear
39" irocks
