"Note 91" Bouncer build
Re: Re: "Note 91" Bouncer build
nhl_bullitt said:
Thanks man!
Honestly, not that I need it, because I don't race much, but I have motor plans. :driving:
Everyone should have motor plans. Lol
Did you end up running the 700/241 or did you find something else?
Correct, went with the original plan.
700r is a K case that is rebuilt and has a few upgraded parts.
241 has the JB conversions super short sye 1350 flange, and side mount. I decided I will fix it the first time it breaks, but if it goes a 2nd time that may be all she wrote for it.
The problem is I don't have 3/4" to give up, down, or back. So if I go with a different transfer case, I will probably have to go with a th350 which brings the case further forward giving me more room.
In 5 years the only time I've blown my 241 up is because I ran a slip joint that had a stop in it one ride and it blew the case in half. That made me buy a 205 and think of new trans/xcase ideas but I think I might wait till I blow this one up too.
TBItoy said:
The way an atlas/np205 is designed, it is a lot shorter than a 241
Cool. I didn't know if it would be physically bigger, but even oriented too much 1 way. The shorter it is though, the more room I have to give.
Good to know dude.
Awesome thread here.. Gives me motivation to keep workin on mine.. I have basically the same combo, 5.3/700/241/tons.. Do you ever shift your t case? I don't see a shifter in your pics, thinkin about just leaving mine in 4lo unless someone talks me out of it.. Also wondering what you guys think of a hack/n/tap on the 241 vs $sye kit? Don't mean to jack your thread, just lookin for real world input from somebody beatin on the same stuff as me...
Good to know dude.
I just saw that you said you had the super short sye. So you'd end up about the same OA or a little shorter if you went with the short atlas tail. but your front driveshaft would be shorter
Yes, I can shift the transfer case. I made a short lever. Just enough there for me to wrap my hand around it (that's what she said).
I didn't look into that option for the 241. I wanted the tcase to be short so I could have a longer driveshaft, so I knew I was always going to get the short SYE. I know it sucks spending that coin on it, but it's what I did. Been great so far. No hijacking worried dude. If you have something similar you're building, I'm down to discuss. I've bugged plenty of people. It's what we do.
My 241 stays in low 95% of the time. I think that's what's made my 700 last so long.
0 Words
