Wildman1
Okay I need some help with this as I am about done with ideas.
Before I repaired the plenum gasket on the intake manifold of my 5.2L it never over heated. Now since I have gotten that done when ever the Jeep is under a heavy load it will overheat. The electric fan is working and pulling the correct direction, I had installed a 185* thermostat but pulled it and put a stock 195* back in. The radiator is new and was cooling the engine fine before. The coolant is the pre-mix stuff which is what I had in it before also.
So ideas? I haven't tested the radiator cap but it is new. Other ideas?
