offroadwheeler
- Joined
- May 20, 2009
- Messages
- 67
Alright guys this is what i got....
1990 toyota 4runner with a 3.0 3vze
I recently pulled the motor and had the block bord and valve job done on the heads along with milling the heads and block. I got the master rebuild kit and put everything together myself other than the valves. I finally finished putting it all together and when i went to start it, i can hear cylinders firing a couple of times and its really shakey but it wont stay running for longer than a few seconds. My guess is that its either a timing or a fuel issue but i have no idea. I took the distributor off and made sure that i wasnt lined up wrong but i turned it 180 and it was worse. PLEASE HELP!
Thanks
Thanks
