BustedKnucklefilms
- Joined
- Aug 24, 2009
- Messages
- 4,302
- Reaction score
- 293
Bumpers said:What t case are you planning to run?
I think he should run the 205
For sure. I don't think you can get much stronger and simpler.BustedKnucklefilms said:I think he should run the 205
paradisepwoffrd said:For sure. I don't think you can get much stronger and simpler.
Will you need a vss for the 6spd & will the 205 work if so? Maybe a nv271 if not
that would be my plan for sure then.Bebop said:VSS is in the trans in the 6l80.
A round pattern NP205 should bolt on a 4wd 6l80e
A round pattern 205 will bolt up. It might need the short input shaft though depending on the trans. And you have to make a small notch in the transmission to transfer case adapter for one of the 205 shift rails. Pretty easy though. If you guys need any parts for this project let me knowBebop said:VSS is in the trans in the 6l80.
Bumpers said:Something I haven't thought about and saw in a few other k5 builds I was reading up on. Think there will be issues with driveline angles using the 6l80 being a longer trans ?
Sent from my SAMSUNG-SM-G890A using Tapatalk
Bumpers said:Updates?
