Project Peanut Butter Jelly
Thanks guys. Luggs, we definitely have to get something set up, it'll be nice to actually do some local wheelin:cool:
Since big tires destroy the world, I recentered some old wheels off a trailer that got scrapped a while ago. These should work well for driving to church on Sunday, and other daily driving duties
Finally got off my ass and finished the other two pizza cutters
Disclaimer: I used a holesaw to cut a hole in this tire. Look up the tire pyrolosis video if you need to know why
When you want to mount tires on it let me know i have a bead hammer and bars....ill come over and help you out.
All ready have all my wheels/tires mounted for it, thanks for the offer though. You still have your roundy round car?
I bet you could do some mean rear steer donuts with the skinnies....
Yes, I can't wait for the day I get to try :redneck:
Cut apart some old driveshafts this weekend. This is the easiest way I have found to do this.
Grind the weld down
Make two cuts, opposite sides
Cut around the weld, then hammer a chisel into the cuts you made
You'll be left with a pile of drive shaft parts
let me know when ur ready to test run her....206-909-9927....emmett...i dig it
liking your idea with the making the two cuts after grinding. when im building my drivelines its usually just cutoff wheel to the weld than hit it with a chisel till they seperate. What U-Joint sizes are you gonna running on this beast? What did you get the D-Lines out of?
Keep up the good work!:beer:
Ya done yet?
:corn:
Of course not
1410 joints, they are the stock 2.5 ton driveshafts :beer:
