project taking too long to finesh.
  • Thread starter Thread starter dja410
  • Start date Start date
I have to pick what rear end I am running permenatly before I do that. With as much as your stretched if you run a doubler behind the th350 you will probably have about the same length rear driveline as me.
Its getting 42s on it so i dont want to do anything like that tell i see how the 42s fit. I did some more work on the dash tonight and tommarow im gonna finish putting the motor trany and case in. I want to put a tube crossmember under it and basicly build a full belly skid to. I also have another set of 8 lug rollers if anybody needs a set their super bald allterains on aluminum wheels.
Motors just about ready to drop in was gonna put it in a week ago but decided to paint it up. Just need to go to the parts store in the morning and get an intake gasket and motor mounts brand new fancey ones lol, :corn:
I meant black with a blue intake and valve cover It ran great has a little bigger cam than a R.V. in it though.
:eeek: really... i was told it has an rv cam in anycase i never got a cam card or any specs on the cam, glad to here it worked out like i said it would :awesomework: i only owned it for about a month, drove the rig to the lot pulled the motor and now it's gone:booo: maybe some day i will have a wheeler again:puke:
Started messing around with the rear cage and this is what i came up with. It is getting on buckett seat in the back so it should work out perfect.
