Propane ?
Re: Re: Re: Propane ?
Paperstreet10 said:
It is an impco, ill have to get back to you on the numbers. The first two times it cut off, I was actually driving down the road running great. Both times I let the truck sit for about 20 minutes and it cranked right back up and drove home. Not sure on age of the system. Ive only owned the thing since Saturday. What's an avg lifespan of a vaporizer?
could be the ignition module breaking down. Then comes back after it cools off
Got my problem solved. My connection between vaporizer (controls flow valve) and ignition was bad. The silicone piled up from a previous owner should have gave it away. The wire protruding from the solenoid no longer protruded bc of where the break was. I got it home from the lake by forcing a fishing hook into the end of this wire and tied in the other end to the eye of the hook. :afro: :****:
I then cut some extra loom off another wire to keep that rigging from grounding out on the 2 mile drive. Afterwards, I was able to pull the short end some and solder it to make a reliable connection. Thought it was funny as hell so I snapped some pics
Buddy of mine had the idea. I think his uncle might be John Mcgyver :****:
Glad to hear ya got it figured out. Really hate that you had any issues at all to begin with since I didn't have those issues with it.
Put my motor in no issues with vacuume yet thanks for info guys
