CHOP SHOP
shoulda just went with sum 2x2:redneck:
3/8th's wall lowers, I laugh. The jonnys will bend. Ive gone thru 6 of em.
So? That's why their rebuildable...I don't expect anything to live under there undamaged.
So will steel. 4130 is spring steel, diameter, thickness, heat treating all play a roll in how much it will bend and how much force it takes to bend it. I did some back yard math and some internet reading and the best I can tell my 4130 links will take about twice as much force before it will permanently bend as compared to 7075 aluminum.However alum will bow a bit on impact, Taking stress off the jonnys/heims. At least the jonnys are cheap.
I bought them that way. I tried to drill out a smaller one but it's too hard to drill with common HSS drill bits.Also, Did you drill em out (thru bolt) or did they come that size?
Mine bent after the thread and before the body.
Also how much thread is showing on yours?
Anyone ever do JJ lowers without the threaded shank (non-adjustable)?
Weld-on, yep lots of them, but I always included a means of adjustment at one end.
I was thinking it would be both stronger and cheaper to have weld-on lowers and adjustable uppers. If you get everything lined up perfect the first time you shouldn't need adjustable lowers right? Or am I dreaming of a perfect world that doesn't exist?
I have used tons of weld on ones with no issues.
why do you need an adjustment? brackets/hangers ****ed up?
The adjustment can be useful when you bend the link and its length changes :;
Also I wouldn't assume that the assembly would be any more stronger without the adjustment built in. If you weld the link directly to the JJ you would need to use the cromo JJ piece in order to have it heat treated afterwards. The body of the cromo JJ is only .188 wall IIRC.
