Queston for you buggy guys with D-60s
jrgaylor's BII is full width (D44/9") to give you an idea
Everything is a factor. Wheel- width tire-size frame-width. wheel base Trailer width. But if you take your time with a tape measure. n a pad. It can turn out spot on perfect.
I have a buggy based off a cj5 dana 60s 44 "boggers 105 wheelbase. It drives right on a standard car trailer. tires dont hit the frame when turning right tight. And its stable and works well.:awesomework:
Go Full width. Play with you backspacing on your wheels to get it were you want to be.:awesomework:
Can't remember the numbers but I am full width with 2" wheel spacers and stock offset H1 12 bolts.
my buggy is roughly 82" front, from outside to outside tire. How do you think it will fit in the NW trails, ie elbe, and evans? Haven't ran this in the trail yet, just seeing how it will fit.
Running 44 up front, 14b in the rear on 39.5TSL x15" wide
I have stock width chevy stuff running 2.5 BS wheels makes me right around 90"wide on the tires with the 44's
You've gotta be way wider than that... I'm on stock GM with 44" tsl's which are way narrower than your boggers and 3 3/4" backspaced 15x10's with DIY beadlocks and I'm right about 91 1/2"
