RCV Big Bells in 05+ F250/350 outers
Yeah don't tell me I can't break something. Then it becomes a challenge.
kmcminn said:
Go buy some 1550s and report back.
Broke a 300m rcv. Is that not good enough for you. O wait I don't have that magical 14 bolt front so it probably wouldn't hold up to 1550s.
Break this and report back.
Sent from my XT1635-01 using Tapatalk
Those Cap's are2.5 in diameter and the cross is 7" long
kmcminn said:
That's impressive. Myself included 95% of offroaders will not break a 14 bolt with 60 shafts.
The reason I didnt go 14 is because i can't afford 40 spline. A good hp60 is stronger than a 35 spline 300m.
Re: Re: RCV Big Bells in 05+ F250/350 outers
Jduck said:
Details??
I think the answer will not be found here...
Jduck said:
Details??
How light is that setup? Going on a diet....
Its probably already been deleted
Stumbled upon this thread thanks for all the info great write up enzo. Me and a buddy are building a set of 14bolt center with f250-f350 super 60 outers. original plan is to run the big bell RCV, after reading and rereading I'm more confused then ever. my question is, the bell will fit thru front side of the knuckle without the booth if the seal lip is machined down or am i missing something?
You got it. Like Jake said, machine the lip and that's it.
The question for me is still
1- can you reach the 4 hub nuts with the bell in the way?
2- How do you get it back out after the bell is in the boot?
1-my guess is there shouldn't be any issue accessing the nuts because the bell necks down
2-I would think same as normal RCV disassembly process. Pop the boot off. pull hub off, slide entire bell and shaft thru knuckle while leaving the orange boot behind
