Rear Engine buggy
Grama
Bend, OR
Motor: 4.3L Vortec
Tranny: Th-350 reverse man
Tcase: dana 300 with 4to1 and big outputs
Front Axle: Dana 60 4.56s 65 WMS
Rear Axle: Dana 70 4.56s 60 WMS
Tires: 42 irocs
Wheels: H1 Double beadlocks
Suspension Rear: 3 Link with Panhard and 14 inch SAW airshocks
Suspension Front: Wishbone 3 Link and 14 inch Fox airshocks
Sweet!!!
That tube thingy is bitch'n!!!
Look foward to seeing the new G (Grandma) buggy in action at Goldendale.
:clappy: :clappy: :clappy:
you build the whole frame? also how do you feel the gearing is with the 4.56's and the 4.1 case and the 4.3 vortec
So far every piece on the thing was bent, welded, noched, or cut by me. All the way from the chassis to narrowing the rear axle and fliping the knuckles on the front.
I bet the 4.56s will be fine for awhile. These axles(wider version) were in my old buggy and it had a 70 BHP 22r on propane and still got it done with only 4.7s in the case. So about 120 more horse will make up for the different gearing.
yeah thats how I've been feeling about the 4.56's. I am building a buggy here shortly from SN Fab and the guys there told me that the 4.56's just seem a little low for the 4.3. I'm going to be using the 4sp atlas with teh 5.44 which in final ratio should be a little bit lower than the 5.13's using a 4.3 atlas case. The 4 sp also has that 2.0 ratio that I'll use when I need a little more umph and more speed than that way low crawl ratio
lookin' pretty good G-ma....
gonna have to bring that over to matt's when the wetness comes back....
we'll talk about it at goldendale.....we're gonna have to set something up...
--B
