So a guy could use the mainspring out of a stock front pack and the rest of the leaves out of a rear pack to get a touch of lift over stock without changing any of the steering due to axle location correct?
I would just think having 2 holes instead of one would make it weak and prone to breaking..... but if it works !
how do you mean pook?
how much lift are you looking to achieve??? there are soooooooooooooo many options!
Well my truck currently sits about 3" tail high with stock suspension under all four corners, I'm thinkin 2.5-3", something that I can offset using just longer shackles in the rear to run 33's or 34's with little or no trimming
why don't you want to move the steering? Still push pull?
you can get pro-comp 4" springs and use stock shackles and you will be level and if you sit a little high in the front then make longer shackles for the back you can pick up those springs for around 75 bucks a piece brand new.
I had a serious problem when I put in my 44044s. I was planning on doing crossover but had to do it sooner than expected because I could not steer haha
Exactly, I can't afford to go with crossover yet but I really need to get my front suspension up off of the bumps. I have almost literally zero compression travel up front.
That's what I'm trying to avoid. I need something that will get my some friggin travel up front but still be able to use my stock steering, at the most changing out the drag link for one of the ones that usually comes with a boxed lift...
I know this may be a little out there as far as the rest of the thread has been going, but it's entirely possible that my worn-out, 24 year-old schocks are what's makin the front end work so shitty? I was fawkin around on the RTI ramp that I've got earlier today and the front springs have virtually ZERO compression travel, cant get the shackle to hit the frame or the bumps to contact their pads before the rear on the same side is off the ground and spinning. They don't droop very far either, a couple of inches, 2-3, at most. The shackle comes nowhere near straight at full droop.
Any ideas?
you have stock springs thats the problem.. you might as well install 3 lengths of 1/4 thick flat bar:haha:
Removing the shocks and seeing what happens is what I plan to do here in the next couple of days. I mean, even stock shocks should have more than just 5-6" of overall travel shouldn't they?
