Jason C
is it me you speak of with RS?
Not you Nate ... any RS car in general. if you come up to a dirt to rock transition and the rig does not crawl up it and "the person" with RS starts weaving back and fourth it makes a trough in front of the rock. if you square up to what your trying to get up and use a little momentum and bump up the step. Not forgetting to let off the gas as you hit so your momentum will carry you forward than rolling "LIGHTLY" back into the gas once on top. hell all the trails around have been made with out RS. I ran OM without it in a car that is 6+ years old as well as many others. I feel all other options should be explored prior to going to RS. Last resort and should be used properly and not in a way that damages trails. Erosion is bad enough. the only thing wors is the guys that need the "bigger tires" and peel the FAWK out on everything. everybody preaches "tread lightly" yet you see people tearing the $hit out of the trails. Treading lightly is breaking as little traction as possible.
